Reyestrec
I own a 2011 Chevy Tahoe LTZ it has OEM wheels on it right now. I bought wheels and tires for it but I want to know if I can use these tires on my Tahoe. The tire sizes are 275/25ZR24 I wanted to know if I can put them on my Tahoe.
blackelky
I have 33 inch tires on my tahoe and it fits. stock wheels with the 275 55 20 measure out to be 32.1. I think what your putting on measures to be 29.5 or something like that
KidWgn
Certified Kid Hauler
St. Louis, MO
That label is about as clear as mud. Check the weight rating for them. I certainly wouldn't roll around on a 25 series. I have 305/35-24 on mine
KidWgn
St. Louis, MO
That being said, I'd probably go with a 285/35-24 on a future wheel. It's a lot closer to the OE diameter.
Reyestrec
Reyestrec
I’ve been hearing different. Some say yes others say no but I’m probably going with your size of tires
CMoore711
Do not do a 25 series tire on a 24" rim; That is way too small. You want to stay as close to the OEM tire diameter as possible. Not sure what you're stock tires are right now, but using a 285/45R22 for stock 22" wheels the tire diameter is 32.125" +/-.
Here is a good site you can use to play around with different wheel/tire sizes compared to stock:
Assuming the 24" rims you're looking at are 10" wide you should be on either a 295/35R24 or 305/35R24 tire. Depending on any suspension mods and the wheel offset the 305/35R24 may rub slightly up front while turning close to full lock. But the 305/35R24 will offer a tad bit more rim protection and forgiveness on $hitty road surfaces and daily use.
jackal78
