2021 Yukon Denali Lowering Kit?
wendal
Dallas
You’re welcome. Did ever look into this?
I did, but it does not appear to be compatible with the Denali and Magnetic Ride Control. I've also read some reviews here that some indicate that there are potential bottoming out issues with these:
I am going to wait a little while longer to see what else shakes out. Ultimately, I really only want a 1 inch front, 2 inch back drop, and that is not yet available via any of the existing kits. I will likely be waiting a year or 2 to see what else becomes available. I had my 07 Yukon for 13 years and will likely have this one a similar amount of time. Lowering it is not something I want to rush into, because I only intend to do it 1 time.
HottnesDenali
I have a Denali but not with the magnetic ride. Belltech said it will work on the Denali without magnetic ride. So I guess I will be good to go. I would like to get the coils because the simple fact I can adjusted the height to my liking. I will also wait a while because I have the stock 20’s. The guy in the review said he bottom out and it looks like he has the stock 22’s. So imagine on the 20’s lol.
Have you ever use any Belltech products?
wendal
Dallas
I did a Belltech lowering kit on my 07 Yukon. It worked well, sat well. 2/3 drop. I did have to replace the front struts after about 6 years. Are you SURE you don't have magnetic ride control? I was told by my dealer that it was standard on all the 21 Denalis.... Just askin...
olyelr
Elk Rapids, MI
Pretty sure all denalis have mrc.
Also, the overall tire size is the same regardless of wheel size.
HottnesDenali
From my understanding the magnetic ride come with higher price packages with the Denali. I was told it didnt come with mines. I will check my build sheet
wendal
Dallas
I ordered mine. Base model Denali + 22's, basically. No extra electronics, not even power running boards. Still have MRC...
wendal
Dallas
Sorry guys thats my fault. I have magnetic ride. I dont have the Air Ride Adaptive Suspension
Make sure you consider this when you get ready to do whatever it is you plan to do. I don't think you want to remove MRC for the Belltech struts. You will not like the ride in comparison to MRC, I'm pretty sure...
HottnesDenali
Thank you. I’m going to wait until you get something lol. New to this truck game. I definitely don’t want to lose the ride quality. We have the same truck except I didn’t get the 22. I have the panoramic roof. Did you get the panoramic roof?
wendal
Dallas
Yep, have the panoramic roof as well.
wendal
Dallas
HottnesDenali
It states it doesn't work with Magnetic Ride Control. That eliminates me...
I call them and they said it will work. It doesn’t work with air ride but will work with magnetic ride. It uses 2 spindle in front with your factory shocks and springs and replace 2 springs in the rear.
2022
HottnesDenali
I will be ordering these soon. Ordering my denali next Monday when I get home from vacation. Once it's actually being built ordering these and a couple other things.
I want to order them myself but also want something a little lower. I like that fact you still use the oem front strut and spring and just replace the rear springs. The ride should still be good
2022
For me that low enough. I'm gonna put 24in replica wheel on to keep the stockish look. Just want to close the gap a little and keep ride quality
mikew2069
If you're just now ordering your truck, you might have a long road ahead of you...
j_jerry79
