2021 Yukon Denali Lowering Kit?
wendal
Dallas
You’re welcome. Did ever look into this?
I did, but it does not appear to be compatible with the Denali and Magnetic Ride Control. I've also read some reviews here that some indicate that there are potential bottoming out issues with these:
I am going to wait a little while longer to see what else shakes out. Ultimately, I really only want a 1 inch front, 2 inch back drop, and that is not yet available via any of the existing kits. I will likely be waiting a year or 2 to see what else becomes available. I had my 07 Yukon for 13 years and will likely have this one a similar amount of time. Lowering it is not something I want to rush into, because I only intend to do it 1 time.
HottnesDenali
I have a Denali but not with the magnetic ride. Belltech said it will work on the Denali without magnetic ride. So I guess I will be good to go. I would like to get the coils because the simple fact I can adjusted the height to my liking. I will also wait a while because I have the stock 20’s. The guy in the review said he bottom out and it looks like he has the stock 22’s. So imagine on the 20’s lol.
Have you ever use any Belltech products?
wendal
Dallas
I did a Belltech lowering kit on my 07 Yukon. It worked well, sat well. 2/3 drop. I did have to replace the front struts after about 6 years. Are you SURE you don't have magnetic ride control? I was told by my dealer that it was standard on all the 21 Denalis.... Just askin...
olyelr
Elk Rapids, MI
Pretty sure all denalis have mrc.
Also, the overall tire size is the same regardless of wheel size.
HottnesDenali
From my understanding the magnetic ride come with higher price packages with the Denali. I was told it didnt come with mines. I will check my build sheet
wendal
Dallas
I ordered mine. Base model Denali + 22's, basically. No extra electronics, not even power running boards. Still have MRC...
SDHanz
