2021 RWD Denali Differential Service recommendations...
JasonHTX
Is there a recommended service interval on the differential?
Blackcar
If you get in glove box in owner's manual there is a list of service intervals and a section of recommended fluids and parts numbers.
J
JasonHTX
Yeah, did that and double and triple checked -- doesn't mention a thing about differential. Have you read the manual?
Blackcar
He’s right, not a single mention of fear diff maintenance in the maintenance schedule. I suggest around 45k, when you do the transmission fluid and filter.
I see that they are not wanting owner to work on vehicle after years of specifications being put in owner's manual crazy.
WalleyeMikeIII
Sunny and Snowy Minnesota
You can always buy the service manual, or subscribe to Alldata. It is tough these days, you need access to all the computers and calibrations (firmware for the various modules) in order to work on your ride.
Agree though, I find it really odd they don't have rear diff service, esp in the "Severe" service section. As I understand it though, there is not even a drain plug on the rear diff, so its a remove the cover, replace the gasket, clean it all out, and refill scenario.
I tow a lot (not real heavy, 4500lb boat), but about 25-30% of my miles. So I get the whole driveline on all my trucks done at the transmission service interval. My service manager says I may be a bit overzealous on the front and rear diff service, but he says the transfer case service is a must (not applicable for you, since you have 2WD), as there is onlly about 1.3 qt in the T-Case.
WalleyeMikeIII
As has been mentioned already, it is not in the manual for the 2021.
Even in the 2017 Manual, there is no specified service interval for the rear diff, only specifies what fluid to use...Honestly, I don't ever recall seeing rear diff service listed in the maintenance schedule for any of the light duty Full Size GM trucks I have owned, including the 2004 and 2013's.
jforb
Sierra Vista AZ
It's listed in the owners manual for my 1959 pickup....change it at first 1000 miles, then every 10,000 miles. As late as the late 1980s, they recommended frequent oil changes in the axles of 4x4s when used in severe service such as dusty or towing. Seems that they relaxed the requirements during the 1990s, when they switched to synthetic gear oil. The 1999 owners manual has no mention of changing.
Stbentoak
And for the record... what are the correct fluids and capacities for the 21+ models?
jforb
Sierra Vista AZ
Per the Owner's Manual...."See your dealer".
I'd look in the service manual, but it doesn't seem to exist.
Jonmurphy
You need to cut the service recommendation in half at least especially when new change it at 10,000 miles make sure it has a magnetic plugged in it and then you can go for maybe another 20 or 30,000 miles that way at 300,000 miles You need to cut the service recommendation in half at least especially when new change it at 10,000 miles make sure it has a magnetic plugged in it and then you can go for maybe another 20 or 30,000 miles that way at 300,000 miles you are still being great
WalleyeMikeIII
Did you read the thread….already stated there is no stated service interval for the rear diff in the owners manual. Also, there is no drain plug on the rear diff, so a mag plug is not an option.
clogan2
FWIW, my brother's '03 2500 Silverado has never had tranny or diff fluid changed, now at nearly 350,000 miles. (He's wasn't big on maintenance). Shop told me at this stage, a transmission fluid change would likely result in a transmission failure.
Pertzbro
Yeah i wouldnt touch it until it blows. Then full rebuild.
WalleyeMikeIII
Thats awesome...and also likely rare; or rarer w/ these more new fangled, "modern" versions...
Does that vintage 2500 have an Allison?
canadiandux
