2021 GMC Yukon XL Denali NO CRANK NO START
TXWELDER
2021 Yukon XL Denali with 6.2. Trans went out last Tuesday, in the shop Wednesday and out Friday. Wife drove it minimally SAT-MON and parked at a store then no crank/no start. Had it towed home.
-She got a message stating "service charging system, vehicle may stall", P0622, I believe a P0615 starter relay or solenoid code and about 15 others that were generic stating "see owners manual for definition".
-It randomly asked her to roll the driver and passenger side windows up and down.
-Battery has 12.8V and was charged overnight to confirm it's condition.
-I cannot find any loose/missing/burned/frayed/disconnected wiring or harnesses anywhere.
-I tested every fuse in the box and the battery top fuses are good also.
-I attempted to bypass the starter relay to see if it would turnover and it does nothing.
-Lights work, radio works.
-Oddly only the driver side auto folding step will come down.
Not wanting to throw parts at it, looking for any advice.
Moderator
People's Republic of Colorado
That first code indicates something wrong with the field connection for the alternator. I would inspect alternator connections carefully and have the alternator tested.
Jimmyy
Minnesota
If the Transmission was out and in so was the starter. I would start there. Checking the cable at the starter visually and with a meter. Check for voltage drop from the battery to the starter (large cable), and check to see if it's getting the command (smaller wire) to start. You'll may need a helper for this. Best of luck and hopefully a Merry Christmas.
blanchard7684
Senior Member
those are an alternator charging circuit code and a starter relay circuit code.
Without a wiring diagram I am speculating that they are somehow interconnected.
I would start with carefully checking the wiring connections on alternator.
Then checking the connections on the starter.
Ground wire on starter?
T
TXWELDER
Thank you, everyone. After Christmas I will take a deeper dive at the alternator and starter and update any findings.
T
TXWELDER
Merry Christmas!
UPDATE:
Two things I was incorrect about in my initial post, one being that the code is a P0617 not a P0615 and the other is that I was bypassing the starter pinion relay instead of the starter motor relay to try and test the starter. I do in fact hear a click when using a jumper wire on the starter motor relay plug but it is very faint and not turning the engine over. Does anyone know if both of those relays need to be energized to engage the starter?
I used a breaker bar on the engine and was able to confirm it does turn over, so not another seized up 6.2L. This gives me hope that I just have a failed starter and could be back on the road soon.
I suppose it could be the battery top bus bar as I see it called out in these situations, but I have continuity across all of those connections. I have no way to verify correct amperage is getting to the starter to turn it.
I will also confirm 12v on leg 85 of the starter relay connection to verfy the ignition switch is working as it is supposed to.
Welcome to the Forum from NH.
Pics of the truck, please.
jfoj
How many miles on your 2021 when the trans failed?
Hodmjstone
