2019 left turn signal failure indicator
Stepho23o
Hi, looking for some help. My 2019 Tahoe recently started having an issue with the left, front turn signal. It is hyper flashing and giving me the warning “left front turn indicator failure“. I replaced the socket and bulb and it’s still not working. Any thoughts on what to do next?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
What does the rear one look like and I would make sure you have a good ground at the front. Then, if that does not help, check back.
S
Stepho23o
Rear is working but hyper flashing. I’ve checked the fuses. But I’m unsure how/where to check the ground.
OR VietVet
Willamette Valley
Not covered under the aftermarket warranty. I know you said the rear is hyper flashing. I meant for you to remove the housings and check the wiring to the back. When you said you replaced the socket, do you mean the whole housing or just the twist in socket for the bulb? What did the contact area look like where the socket twists in? Pics?
Welcome to the forum.
MoundMedic7
