2018 Chev Suburban 5.3L AWD/4WD vs. 2WD
AmazinglySmooth
I have opportunity to drive two different 2018 Suburbans. Both have the 5.3L engine. The 2WD has the trailering package with the different final gear. The AWD/4WD one has the regular final gear ratio. The AWD seems to shift slower than the 2WD. Is this typical? I used to have a 2011 Denali AWD, and I felt it shifted slowly too. I'm wondering if it is in my head or if there is a difference or if there is a maintenance issue I need to handle on the AWD one.
Rdr854
Northern VA
The Suburban is either RWD/2WD or 4WD. We do not have an AWD setting. Some folks have assumed that the transfer case can operate like AWD if you leave it in AUTO 24/7, but I was admonished by my local Chevy dealer that doing so is bad for the truck. Instead, it should be left in 2WD and placed into 4WD when needed.
gat0r
DFW
pretty sure chevy doesnt offer AWD in hoe or burb... just 4wd & 2wd
just the higher end gmc & caddies
i suppose the shifting could seem slower. poss diff in highway vs towing gears. 3.08 vs 3.42 would have different programming for shift points.
how many miles are on it?
if its kept up well... nothing a tune from BBP couldnt fix ;)
ive tuned my '15 burb & it runs great
gat0r
DFW
it is better to leave it in 2WD, but AUTO doesnt hurt anything.
mine has been in AUTO since i bought it ;) im over 60k now
its only engaged a few times when i was on a dirt road or roads were bad from weather.
i move it over to 4HI a few times a year to have some fun launching from start trying to catch a camaro or some other car off guard lol
Jeffrey, the K2s are either RWD or 4x4s, not like your previous Denali.
The difference in feeling may be because of gearing and or programming. Both have the 6-speed transmission but the RWD truck will have 3.42 gears and those shift sooner, a little snappier than the 3.08 gear in the 4x4. The taller (lower numerically) gear affects shifting some. Regardless, a BlackBear tune will make them shift beautifully.
You'll have a 6,000 pound tow rating in the 4x4 and 8,300 pounds in the RWD truck.
All the drive line fluids should be changed if the truck has around 40-50K miles on it.
sealandsky
Minneapolis, MN
"AUTO" setting seems to engage the transfer case as I hear and feel more drive-train noise and feel more drag when it's engaged. I'm not a fan of that, so only engage when the roads are slick (or for a fast launch).
gat0r
DFW
i tried both 2WD & AUTO & didnt feel much of a diff (no diff in 0-60 either)
nor hear a diff in sounds
shrug
4HI is definitely fun for the fast launches :D
sickk23
New Mexico
Mine is a 2018 2wd w/trailer pkg and it shifts SLOW and LATE. Casually driving around town it sounds like I'm in tow haul mode trying to race people. The dealer said its normal but I swear its miserable.
A
AmazinglySmooth
Has anyone that notices the slow shifts added a pedal modifier like SprintBooster or Pedal Commander?
"Auto" does indeed have power running through the transfer case and the front shaft spinning, ready to send power to the front wheels.
Rdr854
Northern VA
I think this is why I had been admonished not to use the “Auto” setting 24/7. It just creates unnecessary wear and tear on the drivetrain.
fozzi58
North Jersey
I live in the northeast and Have been driving a 2WD truck since my 2000 Dodge Ram 2500, then 08 avalanche, and now 2017 Suburban. If the snow is that bad then no one is driving anyways. Unless you are a Nurse DR or Emergency services, there's no need for 4x4 for 2 - 6"snowfalls a year. But then again it all depends on where you live and what you do
Tiredmechanic23
Those things are garbage anyways. They are a mind trick you can get the same effect but just having a heavier foot. Faking a throttle percentage does nothing more than make say 10 percent feel like 20 percent. Its cheaper to just use your foot to go to 20 percent on your own.
blackbear though can tune the trans and speed up the shifts and get rid of the fuel cut on shifts etc and really wake the vehicle up. They are out of Autocals at the moment I believe unless they got more in.
I leave my 18 silverado in auto most of the time and it does drive pretty much identical to my awd denali I cant tell the difference. the difference I can tell is when I put it in 2wd it will do burnouts at will
***and yes a blackbear tune makes a HUGE difference
as far as wear from being in auto "maybe" and maybe it's less prone to breaking the rear end if the power is distributed with some to the front.
Conedaddy
