2017 Tahoe rear A/C
k1970
Oman
Something is wrong with this a/c. The refrigerant is OK, no leakage. It is cold while moving and hot when the car is parking! Any help plz.?
ReaperHWK
If its cold when moving sounds like it's airflow over the condenser issue. At idle the fan needs to pull air through the condenser. Also, if it's dirty can cause this kind of problem. I'd clean out the condenser and check the fan.
Is your fan working properly? Is your refrigerant low? I'd check that too.
k1970
k1970
Oman
What about checking this sensor?
veteran111
