2016 Denali Power Lift Gate Issues
MeMo
Lake Elsinore, CA
My Denali's power lift gate seems to only work when it wants to. Doesn't want to open with the remote, from the inside, or manually pressing the button on the the lift gate itself. I have also tried turning off the power feature (turning the knob by the dome lights) to no avail. Anyone else having this issue?
BuffaloBigJ
Nope... It's a 16 though, so just take it to the dealer.
Sent from my SAMSUNG GALAXY S6 EDGE using Tapatalk Pro
pshrop
I had the same issue on my '16 Tahoe ... ended up being a loose wire. They found it pretty quickly, was covered under warranty. I think they also replaced one of the hydraulics, although not sure if that was necessary.
rattmobbins
My tailgate works fine on my '15 Escalade except that it won't open to 3/4 height like it's supposed to when you select that option from the knob in the vehicle. Only opens full height or nothing at all. :(
So actually I guess it doesn't work fine. Lol
Burby
If it will not open to 3/4 height maybe it was set at full height and it "thinks" you are at your 3/4 set height. I believe the 3/4 is where you turn the knob to manually set your stop point. I could be totally wrong though...
FRED13
I have the same issue.....did you find a fix ? tks
MeMo
MeMo
Lake Elsinore, CA
Ya, apparently they didn't seal the grommets properly in the factory so water/moisture got into the trunk lid area and rusted everything to hell. They basically tore the interior of the truck apart and replaced a ton of wire harnesses, connectors, and the trunk lid "computer".
FRED13
Can you post a copy of the work order so I can show it to my dealer ? much grass :)
MeMo
MeMo
Lake Elsinore, CA
Thanks....not what I wanted to hear....lol
Lol sorry, but hey better to at least have an idea of what's up rather than going my route. My truck was in and out of the shop constantly for the first few months because they could identify the problem.
roflwaffle
