2015 Yukon Denali stuck in lockdown
those fuse panels do there job but the engineers need a whack upside the head, makes no sense to make a one piece fuse panel other than ease of assembly on the production line
K
KFPanda
no you don't want to make things worse, get a new one.
I did the same thing once "sort of" I was installing a stereo amp and the amp was bad out of the box so when I hooked it up and turned everything on it went up in smoke and blew probably the same 170a fuse since I figured that was a good one to use for the amp, truck wouldn't start after that and I figured I was going to have replace a bunch of stuff but I started checking and found that fuse blown, went and bought a new one and thankfully everything worked.
Yeah I will just get another one. Of course this would happen on Labor Day weekend so I may be grounded until Tuesday at best.
K
KFPanda
Auto parts stores are open today and tomo….
Dealership service departments all closed today and possibly tomorrow. Advance auto is not going to have this but I am considering going there for a 175A mega fuse and see what I could cobble together.
PG01
Up here to the right
Yes they have those which is what I was referring to cobbling something together on my existing broken block. But no I don't think those stores have the GM battery distribution block # 84354716 that I need.
My bad, I misunderstood.
IMG_7651.jpegLooking at my ‘19 it looks like there are 2 posts for 175…. How many wires do you have hooked up… only 3 on mine. Move the wire to 2nd post temporarily to see if you can start it…
K
KFPanda
Best solution I have at the moment is 2 short battery cables with a 175a mega fuse between and connect the cable between the 1st post with the bad fuse and the last post that also connects to the battery positive. I just need to see if the parts store has those bits. That I could drive on indefinitely.
K
KFPanda
Well she is up and running. About $40 for the fuse, holder, and cables. I threw on a baggie for a little extra protection. Thanks so much Doubeleive for the heads up!
Instigator01
