2015 wheels on 2004
Red Rider
Hi all,
I have 2004 Z71. So I am looking to upgrade my wheels from 17" alu, to 18" from a 2015 Tahoe. It is a direct swap right? TPS sensors will work and all?
Does anyone know what they are worth, for a set of 4 wheels with OEM tires with little use?
NathanJax
Vacation Nathan
Jax, Fl
Direct swap, yes. TPMS sensors will not work though
R
Red Rider
What is up with TP sensors? they are different? Damn... Any way to upgrade system inside truck?
NathanJax
Vacation Nathan
Jax, Fl
Sensors swapped with body styles. And no, no way to upgrade the inside
TheAutumnWind
You can have the ones in your current wheels installed in the new wheels. Or ignore the tire pressure warning light like I do in my jeep.
R
Red Rider
I am new to TPMS. Trying to figure it all out. I would love to have them since it at least gives you a heads up. Though I am hands on so would most likely know if something is wrong and keep an eye on tires. I would hate to deal with constant light on from fault.
Are TPMS batteries replaceable?
I was hoping to sell the old wheel with tires. If I do, i guess I can buy new sensors. If I can't, I can reuse sensors. Walmart does tire swaps for 12$ each tire. Buying new sensors and installing will probably set me back 200$
I guess I can always sell 2015 sensors and recoup some of that cost.
---------- Post added at 10:07 AM ---------- Previous post was at 10:05 AM ----------
Anyone know why TMPS sensors changed over years? Is there more info provided to computer from new sensors? Just curious.
yates ™
Resident Apple hater
Iowa
If you still have the same TPMS from 2004 I would just buy new sensors and have them installed.
NathanJax
Vacation Nathan
Jax, Fl
No batteries aren't replaceable. It's a sealed unit. Just take your sensors out of your current wheels and put in basic valve stem cores. Then put your current sensors in new rims. REALLY easy.
R
Red Rider
If batteries are not replaceable, how do they check if they are still good? I bought truck last year. I have no idea if sensors were replaced (i have paperwork, but misplaced it, though even if it states replacement, it is no guarantee that it was done.)
Does Walmart and costco sell their own TPMS sensors? Does anyone know how much they charge and if they are any good? I have seen some generic models that can be programmed depending on vehicle they go into.
yates ™
Iowa
That is why I said just buy new ones, they are like $160.00 on ebay. Me I would personally rather spend a little money on new sensors than to pay to have old ones changed over then replace an old one in the next month or so.
NathanJax
Vacation Nathan
Jax, Fl
You'll get an error on the DIC and shops have the equipment to see if the sensor is sending a signal or not. If it's not, they replace the sensor with a new one.
They are made buy auto part manufactures. So Walmart and Costco "could" sell them, just like they sell oil fliters.
Just look on ebay for your years truck... "2004 tahoe tpms sensor"
R
Red Rider
Crap. For $160, I can buy a replacement tire. Seems hardly worth it. But then you got to deal with lite tire warning and chimes.
criffaaa1
One more thing to consider when deciding to buy new or swap sensors is, sometimes they break when you remove them and have to be replaced anyway.
R
Red Rider
I spoke to Walmart. They don't touch TPMS, don't install them, don't reset them. That is weird. What is the point of getting tires installed if you are going to have to take them off again to replace sensors at another place? I am surprised they can get away with that with liability.
R
Red Rider
Ok... So i picked up a set of 2015 18" tahoe wheels and tires, brand new, take offs. Now I need to replace the TPMS sensors. I am hoping to salvage OEM ones in 2015 to sell them, and recoup money from buying new ones.
Are the lug nuts the same on 2004 and 2015? 2004 had lug nuts, then some cheap fake bolts that covered lugs. Kind of weird setup.
Not sure if i need to add a lock to prevent theft?
Another Walmart said they would change TPMS if i brought my own for $20 for all 4 tires.
NathanJax
Vacation Nathan
Jax, Fl
Very easy to do
yes all lug nuts are the same as far as thread. However, different rims could use a different style and even if they both fit, if you get really small lug nuts they might look weird in a hole designed for bigger lug nuts.
Lug locks are a deterrent, just like door locks. If someone wants it bad enough, they will take it. I'd get them though
That's not bad. They need to rebalance them since they will be breaking the tire from the rim.
R
Red Rider
I have looked all over the internet but have not been able to find any information on why GM changed the TPMS system in 2007+ trucks. I would assume there was more info relayed to driver on new trucks. I read that you need to relearn the TPMS sensors after a tire rotation.
---------- Post added at 01:25 PM ---------- Previous post was at 01:14 PM ----------
Found this in the manual:
TPM Sensor Identification Codes
Each TPM sensor has a unique identification code. Any
time you rotate your vehicle’s tires or replace one or
more of the TPM sensors, the identification codes
will need to be matched to the new tire/wheel position.
Each tire/wheel position is matched to a sensor, by
increasing or decreasing the tire’s air pressure.
The sensors are matched to the tire/wheel positions in
the following order: left front (LF); right front (RF);
right rear (RR) and left rear (LR).
You will have one minute to match the first tire/wheel
position, and five minutes overall to match all four
tire/wheel positions. If it takes longer than one minute,
to match the first tire and wheel, or more than five
minutes to match all four tire and wheel positions the
matching process stops and you will need to start over.
I guess newer TPMS do this with an electronic tool.
yates ™
Iowa
They should all do it with the tool I believe, the way in the manual is if you do not have access to the tool you can do it that way.
GM makes it too hard :imo:, my Ram automatically relearns them in a few miles.
R
Red Rider
Yeah. It seems like it would be pretty easy for computer to figure out where each signal is coming from and do it on its own. So I guess it will tell the user exactly what tire is flat or problematic, if properly configured?
yates ™
Iowa
They just tell the computer what PSI is in each tire which is relayed to the DIC. Pretty basic.
