ReaperHWK
- Joined
- Oct 14, 2020
- Posts
- 1,019
- Reaction score
- 1,245
I have a 2015 Tahoe LTZ with factory HID's.
I upgraded the D3S bulbs to some 6000k ones, and I adjusted the low beams for the proper aiming/cutoff. That's all good. I also installed LED high beam bulbs as well.
I notice that when I put on my high beams, the driver side high beam light is projected right above horizontal(therefore looks correct) but the passenger high beam is shooting up about 30 degrees hitting the trees. Is this the way it's supposed to be? On my other cars the high beams(both driver and passenger) are projecting the same. I'm using the same type LED bulb in those cars as well.
Before I start replacing bulbs, is this the way it's supposed to be(meaning the passenger high beam aims higher than the driver?)
I also see that there is no adjustments for the high beam in the manual. Is there any way to adjust the high beams if it is indeed not a bulb issue?
