2013 Tahoe w/ 3.5" Lift, 22" Snowflake Replicas & 33x12.50 Tires - Before and After
Mike Shabo
Absolutely BEAUTIFUL. My last question is what did you do about your auto ride ? Did you just ditch it altogether or use threaded rod to reconnect it? I’m about to pull the trigger in the same lift but this was my last “hurdle” to address before I do.
ericscott44
ericscott44
I didn't have to adjust the auto drive. I assume you are talking about AWD. Everything works as expected since the lift technically keeps all angles close to factory .
ericscott44
ericscott44
I didn't put the lift on so the kit could have the rod you are speaking of .
ericscott44
ericscott44
My truck doesnt air bags, I know a lot of the lifts I looked at did not work with air systems .
Mike Shabo
That’s what I was getting at. The air ride. I’ve got it in the Denali and I keep seeing that all these kits don’t work with air ride or AWD but work with 4wd
ericscott44
ericscott44
Yeah don't have air ride but my AWD seems to work fine .I normally leave it in 2WD but have tested the AWD and 4WD and had no issues .
ericscott44
ericscott44
If I hit severe bumps in a curve my traction control will kick on.
Bmorey67
Thanks for the pictures bro. I have the same truck. I’m putting a 3.5” lift kit on mine as we speak. I’m debating whether to put the 33s like you have or go with 35s. It looks like the 35 would clear them with some trimming.
