avalonandl
Ahhhh....no
Have you thought about spraying some silicone or WD40 up around it and see what effect that has?
Maybe.... I just might take that one apart and see if I can add the insulator GM recommends and see if that helps. I can get at all the bolts but the front one. need to take the front bumper cove off to get that one. then just jack it up.My GUESS is replace ALL the mounts.....
I was thinking about doing almost exactly this. I was going to take the mount out someday and install the insulators noted in a TSB for this issue. If that didn’t do it I was going to fill that cavity above it with two cans of filler to deaden the sound. For now I use the radio.why not just shove something in there to make it tight? **** loosen it spray some foam cavity filler in it and bolt it back up, done
Thats the one. Pretty sure thats whats going on. I wonder if the actual TSB was updated to include more years.
Just a thought as we like to help spend other people's money here, but since you will need to take all the mounting bolts out at least on the one side of your vehicle, why not just replace all of them on that side and be done with that side.Ordered the insulator, upper and lower body mount. Not happy to have to lift the body up off the frame but will update as things progress.
From what I have read as well as what I see form a visual inspection all my body mounts are in good shape. I understand the noise is due more to the design and movement of the mount rather than the condition. I ordered the mount parts too as insurance so I have them in hand when I take it apart. Replacing all of them would come to the tune of $400 per side.Just a thought as we like to help spend other people's money here, but since you will need to take all the mounting bolts out at least on the one side of your vehicle, why not just replace all of them on that side and be done with that side.
I see - Like I said, we like to help spend other people's money.From what I have read as well as what I see form a visual inspection all my body mounts are in good shape. I understand the noise is due more to the design and movement of the mount rather than the condition. I ordered the mount parts too as insurance so I have them in hand when I take it apart. Replacing all of them would come to the tune of $400 per side.
