2013 Chevy Suburban LT heated steering wheel upgrade
chevyguysuburban
I want to upgrade my steering wheel to a heated steering wheel. I would like to know if it possible for a plug and play, or would there have to be other wiring done to make it happen?
you need the steering wheel with heat option and a clock spring that matches it, then you just need to run a power wire to the clockspring from a accessory power source.
the clock spring sends the power to the steering wheel you just need to connect the power to the clock spring connector.
you want accessory power so that you don't ever even accidentally leave the steering heat button on and drain the battery.
you can find the bcm power pin outs with the gm upfitter guide which is free online
mikeseay
Air Force Supporting Member
Kingston Tn
I believe want he is asking, is the wiring for the heated steering wheel already in the wiring harness?
Prior to being an option on a particular vehicle we would need to add a wire like you mentioned but like adding a Cadillac or Denali dash in my 2005 in order to get a transmission temperature gauge where most of the wiring harnesses have the wiring for the gauge installed and you can just plug it in and enjoy it.
has to have the clockspring and has to have a power source behind the clockspring
C
chevyguysuburban
So what you are saying is I would need to add a power source and get a new clock spring with the heated steering wheel option?
C
chevyguysuburban
Or could I just by a new clock spring with heated steering wheel option and a new steering wheel?
it's the same thing lol
you have to have a steering wheel that heats and you have to have a clockspring that provides power to said heated steering wheel.
it wont work any other way
the clockspring needs to be connected to accessory power in order to send it to the steering wheel
and if said heated steering wheel and clockspring have radio buttons normally the buttons just work no further wiring needed, the only thing that needs a wire is the heat option
petethepug
Michael
SoCal
* Must have 07-14 full size SUV or 07-13 full size pick up with steering wheel heat element embedded option.
* Purchase OEM clockspring with equipped for heated SW option. Aftermarket Dorman clockspring known to have issues.
* Review posts on the install procedure and where to pull a single power lead to it. Approx 07/08 used an in line fuse from the fuse box and approx 09 used a dedicated lead from the fuse box marked for steering wheel heater.
buckwild27
EMT/First Responder Firefighter
Ohio
So what would be a good place to get the heated steering wheel option hooked in?
I have the required pigtail to hook that up if you're interested. I never used it now i don't need it.
FatBob
You are correct.
I will add you need to also run a ground wire.
From experience with a 2011 Silverado, be sure to use an accessory 12 volt source. The battery will still drain, even if the switch for the heated wheel is not left ON. I had to rewire mine from a hot at all times to an accessory switch 12 volt source. No idea why the battery drained, but the heated wheel was not turned on.
buckwild27
Ohio
You are correct.
With the stuff i have it plugs into the factory port for the heated wheel
Hodmjstone
