2012 Yukon shudder/vibration around 1000 rpm and other quirks...
Geotrash
Dave
Richmond, VA
As I understand it, when your AFM system is creating this much noticeable shudder, it's likely that the lockup clutch in the torque converter is getting really worn, hence the shudder. When that finally goes, it'll send shrapnel through your transmission, cooler and lines. I just replaced my torque converter with an HD unit that had a billet case and upgraded lockup clutch materials to avoid this problem while doing heavy towing this summer.
wsteele
Hey guys,
I just recently purchased a 2012 Yukon SLT with 57k miles. The car seems to be in great shape overall, but I'm definitely new to the world of Yukons/Tahoes...so I'm hoping you all could offer some expert guidance.
I did do some searching in these forums beforehand about my problem and I'll share what I found below.
Main problem: when I drive on city streets and get to around 30 miles or so and start coasting and the RPMs drop to around 1000 or so...I notice this shudder/vibration as soon as I give it a little gas. It completely goes away at about 1100/1200 rpm.
I kept trying to pinpoint if it was more connected to speed or RPMs and I realized that it was mostly about the RPMs. Even if I'm going 40 or whatever...once it drops down to 1000RPM and I give it a bit of gas, there goes the vibration.
It's not a really strong shudder/vibration, but it's noticeable and annoying. It drives so smooth beyond that quirk and I'd like to get it addressed.
From the posts I've seen, a few have called out:
- Driveshaft alignment
- Torque converter
- U-joint
I'm curious what you all think.
Beyond that main issue, I noticed a few more small quirks:
1) a very slight whining when I turn. Is it normal to whine a bit or could that be a power steering issue surfacing?
2) vehicle start is a little slow in the beginning, almost like the battery is going. It turns over a little slow and then starts right up. I am guessing if I get the battery checked, they'll be able to check the alternator too? Been a while since I've had an issue like this.
3) the vehicle has remote start and it doesn't seem to work if the car has been sitting a bit. but if I click the lock button then hit remote start, it works. I wonder if that's somehow connected to the battery/start issue.
Thanks in advance for any help you can offer!
I have a 2007 Yukon (kind of the worst case for AFM issues) and I have never had the shudder you describe. I have read others who have had it, so I know it is real and the way you describe when it happens, it sure sounds like your AFM switching from V4 to V8 mode is the trigger.
I turned AFM off on my Yukon with a Diablo Predator 2 tuning device. All the AFM hardware is still there, it just doesn't switch back and forth. I think in later model years like yours, a lot of the AFM issues have been addressed (the ones that may actually lead to a more substantial engine problem), but I don't think they are 100% problem free.
I would also heed what @Geotrash noted about the actual source of the shudder. Maybe have a competent transmission tech take a test drive and see what they think.
Along with Foggy's list of good things to do, maybe consider one of the many ways to turn AFM off in your engine. It might be as little as $50 for an ECM reflash to turn it off, I think most on these threads would consider it money well spent.
Finally, on the slight whining when turning. If your Yukon is 4WD and you have the option of 2WD, Auto, 4WD high and 4WD low, make sure you have it in 2WD and see if it is still whining. If you were in 2WD and get the whining, it is more likely steering than transfer case noise.
MmmBrisket
MmmBrisket
You can kinda keep the AFM from kicking in: put the gear selector in manual mode,
then put it in 4th gear.. It will shift normally from 1-4 gears... And the afm should
not kick on.. Try that to help pinpoint your issue.
Spot on! I just tested it out and that's exactly what it is...as I didn't feel the shudder at all. Now to tackle the rest of that list!
MmmBrisket
MmmBrisket
Wow, that sounds like a nightmare. I don't think I'll be doing any really heavy towing...but I suppose it would be good to know what you consider "heavy". I'm guessing when I tow, it will likely be 5k or less.
Would that necessitate a HD torque converter? Or maybe I can get by with the standard deal. Going to have my mechanic give it a once over as well.
wsteele
I towed about 5,000lbs (tandem axle enclosed trailer) quite a bit of the time for about the first 60K miles of my Yukon's life (HD towing package, top brand trailer brake controller, etc.). I had to do an emergency replacement of my transmission (stranded on the highway outside Reno NV) at 76K miles. so... ;)
MmmBrisket
MmmBrisket
Don't think this is worth starting a separate thread about, but does anyone know what this crazy thing is?
At first I just saw a dent in the quarter panel near the door jam...then pulled the weather strip back (which was loose) and saw a black cap. I easily pulled that off and there was this crazy looking hole drilled.
PXL_20210408_235221691.jpg PXL_20210408_235236130.jpg PXL_20210408_235247174.jpg
Foggy
KS
View attachment 275815 View attachment 275816 View attachment 275817
That's classic "Paintless Dent Removal" ... They drill holes in unseen areas to
use tools to go in and massage out the dents/hail damage... it's way cheaper than
doing actual body work.... but..... it leaves a hole that can easily rust...
Clean up the area and put some paint/primer on the metal so it doesn't rust.
Then put back in the plug and drive on !!!
As far as your AFM/DOD: if you want the easiest option, get a Range Brand
delete module.. If you want a better driving experience, get a tune.
The guys here love their blackbear tunes... better trans shifting, better performance,
and sometimes better MPG.... either way, get the afm turned off somehow. it leads
to issues
wsteele
Maybe a patch left by someone who did some paintless dent repair? (wild guess).
greygranny
