2012 Tahoe transmission shifter
My 2012 Tahoe after pulling into a parking space, wouldn’t shift into park, or any other gear for that matter. Was stuck in drive. Shift lever was very loose and nothing registered on instrument cluster. I set emergency brake and turned off engine. Unable to restart since I couldn’t put into PARK. Had to get it towed to dealership. No word from them on what has failed,, yet. Any idea what could have happened?
Richard Blakely
Thank you! I was afraid it was a transmission failure. I’ll wait for dealer results!
Richard Blakely
Transmission shift cable broke. Comes with 2 cables to replace, one exterior and one interior joined together. Replaced by dealer for $384, bargain as far as I’m concerned!
Had a big rig blow a tire right in front of me once, took the "gator" down the center between the wheels and thought, whew! that was close. Couple hours later went to pull into a rest stop and the shifter just flopped around and couldn't get her out of gear. Set the parking brake, crawled under and manually shifted into park. Had to crawl under a few more times to get it out of the parking space and pointed towards the highway again and then replaced the cable the next day. Happened again six months later!
Richard Blakely
Interesting!! That happened to me before the failure too, With a guy’s trailer that blew a tire in front of me and thought nothing of it until you mentioned your experience.
St. Louis
There isn't one for the tranny from the factory that I know of. It would have to be an aftermarket/custom part I'm guessing.
dirtydenali07
Do you remember what length the cable was? I just posted new thread. I have same problem, rock auto lists 2 lengths for lower, advance lists the longer one only, and summit racing doesn’t list my 07 Yukon Denali XL for the shorter one.
TallHoe 96 OBS
