2012 Suburban LT w/autoride
12LTBURB
Hi All,
I am new to the site and new to the Tahoe/Suburban line. I am curious if any one has put the bilistein strut lift up front and a 1 inch spacer in the back with bilsteins in the back and 275/60/20's tires and had any problems with rubbing or with the auto ride. This is my wife's so i don't want it to be to high just can not stand the rake low to the ground look. I just got rid of my grand cherokee with the bilstein strut lift and thought it made a huge difference for the better in that. Just an added thought I will be hauling trailers so I was thinking of possibly going with the Munroe coil over shock in the rear instead of the bilstein.
Thanks
Derek
12LTBURB
I think I was mistaken about the auto ride! Is there something that stands out that I can make sure?
Thanks
z0lt3c
Central NJ
You can email Jennifer @ [email protected] and send her your VIN, she will reply with a decode of the RPO codes for your truck. You can also look them up in the glovebox. I am not very familiar w/ the NNBS but on the NBS a give away is to listen or look for the rear air compressor, it runs with the key in the acc position for a few seconds.
12LTBURB
Thanks for the info. I am almost positive there is no compressor. I got the LT model which normally does not come with the auto ride but the previous owner put some many option on it I wasn't sure.
NathanJax
Vacation Nathan
Jax, Fl
Look at the rear shocks. If there is a small air line going to what looks like a bag built in to the shock, that's autoride. If it looks like a normal shock, then no autoride.
dizhai
