2010 Yukon headlight lamp change
Robert Sparks
Kentucky
I just purchased a 2010 Yukon Denali and love it. I want to change the headlight lamps to a Sylvania Silverstars. Can someone tell me the proper / easy(if there is one) procedure to change the lamps. I started and then stopped. I had an Expedition and knew just how to do it. But I am a little worried to do this on a 3 week old Denali. Thanks in advanced for you help.
Sweet_N_Low
What are projector headlights?
Wikipedia says:
[edit] Projector (polyellipsoidal) lamps
Projector optics, side view
Projector headlamps on an Acura RL
In this system a filament is located at one focus of an ellipsoidal reflector and has a condenser lens at the front of the lamp. A shade is located at the image plane, between the reflector and lens, and the projection of the top edge of this shade provides the low-beam cutoff. The shape of the shade edge, and its exact position in the optical system, determines the shape and sharpness of the cutoff.[17] The shade may have a solenoid actuated pivot to provide both low and high beam – the shade is removed from the light path to create high beam, and placed in the light path to create low beam, and such optics are known as BiXenon or BiHalogen projectors, depending on the light source used. If there is no such arrangement, the cutoff shade is fixed in the light path, in which case separate high-beam lamps are required. The condenser lens may have slight fresnel rings or other surface treatments to reduce cutoff sharpness. Recent condenser lenses incorporate optical features specifically designed to direct some light upward towards the locations of retroreflective overhead road signs.
Hella introduced ellipsoidal optics for acetylene headlamps in 1911, but following the electrification of vehicle lighting, this optical technique wasn't used for many decades. The first modern polyellipsoidal (projector) automotive lamp was the Super-Lite, an auxiliary headlamp produced in a joint venture between Chrysler Corporation and Sylvania and optionally installed in 1969 and 1970 full-size Dodge automobiles. It used an 85 watt transverse-filament tungsten-halogen bulb and was intended as a mid-beam, to extend the reach of the low beams during turnpike travel when low beams alone were inadequate but high beams would produce excessive glare.[24]
Projector main headlamps first appeared in 1981 on the Audi Quartz, the Quattro-based concept car designed by Pininfarina for Geneva Auto Salon.[citation needed] Developed more or less simultaneously in Germany by Hella and Bosch and in France by Cibié, the projector low beam permitted accurate beam focus and a much smaller-diameter optical package, though a much deeper one, for any given beam output. The version of the 1986 BMW 7 Series sold outside North America was the first volume-production auto to use polyellipsoidal low beam headlamps.
wodzio78
I actually went different way to install HID in my 2011 Yukon Denali. I didnt want to take out Headlamps or lowering Bumper cover to get to headlamp screws. On the driver side I just unsrewed WasherFluid holder and then popped plastic push pins holding rubber cover behind headlight. This way you have all the room you need. On passanger side I took air filter cover off , then i took out air filter insert, this way you can just pop Air filter bottom cover right off which is held in place only by 3 push tabs. Once again this will give you access to Rubber Cover behind the Headlamp held by plastic push pins. Planty of room after this.
---------- Post added at 10:06 PM ---------- Previous post was at 09:57 PM ----------
I dont know about being it cheaper then Silverstar Bulb. If you go with no name China made HID's that will last u probably a year if so then yes. In my case my HID was around $220.00. I bought PHILIPS DIGITAL HID Low\High Beam in one (German made not Chinesse). But then again PHILIPS makes great product ... thats why you are paying $220.00 for their HID's. I guess if I already decided to put HID's in my 60K car I rather have good product then worry if the cheap ones will fry my wiring or if I will have to replace them after 6 months.
hbr
Summerville, SC
AmazinglySmooth
Why is it so complicated to change the light bulbs? This procedure is ridiculous. I guess if they used bright enough bulbs from the factory, it wouldn't matter.
gitrduun
Dunno if anyone saw on the classifieds. I've got a set of hids that will fit the nnbs low beam if someone isn't happy with the brightness of their bulbs lol
AdrienR
