2009 PPV with two issues
Sofi09
Hey all long time reader here great group of like minded enthusiasts... now I need a little help. My 2009 pPV with 187xxx miles is in the shop for two reasons.
1). Sometime it’s a hard start and the dash will say reduced power mode. Barely runs and has no acceleration
I can us the cheap harbor freight scan tool to clean the check engine light the truck will run strong for the duration of the ride and mist likely days afterward.
2). I have no fan speeds on the from HVAC
The rear kicks in and works but the front is dead
Thanks all
balln2k11
I would recommend the affordable scanner of BlueDriver, which works amazing on GM vehicles for about $99. If it’s in the shop, they will likely tell you what’s going on and DIY the issues yourself with the help of this forum.
wjburken
Eastern Iowa
Thanks all
Do you know what the codes are behind the check engine light?
Sounds similar to what happens with bad accelerator position sensor issue.
Jason in DLH
Cheeseburger and Fries
MN
Just wondering when was the last time you changed spark plugs?
Jason in DLH
MN
Oops..just noticed about clearing the code and then it runs fine. Most likely not the plugs then. ;)
xx_ED_xx
Possible dirty throttle body causing blade to stick, wiring or tps issue. Scanner data is key plus the actual codes
RichardCranium
Mebane, North Carolina
This caused a reduced power issue and strange driveability issues on my PPV. I took the TB off totally and gave it a severe douching, it was really gummed up bad. I also had to replace my throttle position sensor, and I didn't have a Tech2 to learn it in.......so I had to drive it for over a week before it learned the correct parameters. It was a hairy ride, like trying to tame a wild colt at times. I don't recommend doing a TPS that way. :)
Sofi09
Sofi09
Thanks all I don’t have the truck back yet. Been at shop for about a week
I’ll provide kore info as I get it
Sofi09
Sofi09
Sorry I had elbow surgery and was tied up
Picked truck up yesterday
Blower motor, resister for the heat and a new fuse panel that took car of the reduced power
Feels good to have my Tahoe back. Now just need to be able to drive
Thanks guys
Brace
