2009 Denali/Front diff question....
BD104X
Freehold, NJ
Hi all... just got a new-to-me 2009 Yukon Denali. I'm getting a howling from the front diff & weighing my options between rebuild or replace with used. There are 2 parts trucks near me, one is a regular Tahoe & 1 is a regular Yukon (not LTZ or Denali). Anyone know if the front differential is the same on the part-time 4WD trucks and the full time? I know my truck has the GU6 & 3.42 axle ratio and obviously the ratio has to be the same, but not sure if they all use the same differential? Thanks for the help!
Geotrash
Dave
Richmond, VA
You might have more luck posting in the 2007-2014 section. Hopefully one of the mods can move this for you.
The front differentials are different between the AWD and 4WD trucks. You'll need one from a Denali. Or, any good driveline shop can rebuild yours. It'll run $1200-1500 and parts are widely available.
thompsoj22
tear yours down and diagnose it, then rebuild what you have. I'm having a hard time understanding $1200-$1500? yikes! gear set, bearings and install kit $500. It isn't brain surgery? either way salvage donor vehicles are old and run out, keep what you have and rebuild it.
Bill 1960
Testing the Limits
Have you had any work done in a shop lately? Hourly rates are north of $150/hour in most places now.
You are correct I’m sure, that DIY would save a bunch. If a person can handle the gear setup, which as you say isn’t brain surgery. But it is fussy and requires precision and patience and may be beyond the comfort level of some home wrenchers.
I would have sold one of my kids, I was so sure my front differential was howling so bad and it turned out to be the tires!
rockola1971
Indiana (formerly IL)
The only difference between the Awd and 4wd differentials is the extension housing and right side shafts. The 4wd has the actuator as well. Those parts can be swapped from one to the other pretty easily.
Exactly. You can also direct swap in a 4wd diff into a Denali and all you have to do is remove the actuator and there is a aftermarket place that sells an adapter that goes in place of the actuator and it pushes in on the lever to make the 4wd diff a AWD all the time diff. The adapter uses the original bolts of the actuator too and bolts right in place. This removes the work to changeout the extension housing and passenger sideshaft but as you said. That part isnt too hard to do.
Warriorpluto
Have an link for the part?
rockola1971
Ill have to go back in youtube vids. I learned about it on PowerNation.
Found it:
Goto 3:28 mark for explanation and installation of part. They performed this mod on our bodystyle truck and installed it in a OBS K1500 (Project Red Tide). Dont pay any attention to frame mod, doesnt apply to our bodystyle.
Part: https://www.summitracing.com/parts/pos-1000
Part shown is for OBS fron diff. Will likely have to contact manufacturer for part# for our front Diff. According to date range listed on summit it is strictly for OBS.
Warriorpluto
Found it:
Thanks alot
Recently, on LTs own youtube channel, he discovered that the internals of the AWD and 4x4 front differentials on the GMT800s were more different than originally thought. He goes through the differences.
I do not know if this translates to the 900s, would have to pour over the parts diagrams that AAM provides.
91RS
GA
The AWD and 4WD differentials are different. Don't buy a used one, it will have or eventually have the same problem you have now. Buy a rebuilt one (especially if you intend to replace yourself) or have your's rebuilt and be done with it.
intheburbs
SE MI
Ok, so I'm a little confused here. An AWD vehicle needs a third differential to account for differences in speed of the front/rear when making turns. Crank the wheel of a 4wd vehicle on dry pavement and you get heavy resistance and tire scrub. The Denalis have that third diff on the pinion/input of the front diff.
If you're just swapping in a 4wd front axle and locking it in by removing the actuator, how is that going to work when you want to make a turn? You have no third diff in that setup.
91RS
GA
Are you talking about the transfer case? The transfer case is different as well. The AWD differential is open and never locks.
rockola1971
Slippage between front and rearend is accomplished via the Borg Warner AWD Tcase. There is no "3rd differential". The AWD and 4WD front ends are the same (assuming same gearing) except for the passenger side of the front diff. The AWD does not have the actuator that a 4wd unit has. An AWD front diff is locked into "4wd" all the time. A 4wd front end can be locked into 4wd for AWD purposes (when installed in a AWD vehicle) by either removing the actuator and installing an aftermarket spacer/lever that actuates the lock in at all times OR by hot wiring the actuator to be on all the time which I do NOT recommend since the actuator is likely not 100% duty cycle rated and will live a short life. You could also remove the passenger housing of the front diff from a broken AWD unit and install in a 4wd unit. Its a direct swap. Both frontends are direct bolt in for each generation of K chassis.
Mookon
Will a Gen2 front end work in a Gen3 without major modification?
1948Buickroadie
