2008 Hybrid/Bad battery?
BG1988
I think my battery is not charging it was at 12.2 volts last night when I shut it off
i also have freeze frame data with it at 11.6(HV cooling fan code P0C32)
was reading 12.0 today
the DIC is reporting 15 volts(14.6 from the OBD reader dips as low as 14.0 when load is applied) i.e A/C head lights etc..
or is it the AFM disable module not going into sleep mode??
I have new battery cables (I have yet to install)
update i put the new positive cable and it's 14.36-
14.41 with full load applied i.e everything on including the rear A/C
without load it's reading 14.76 volts
Cammed 2002_Yukon
