2008 6.2 No compression in two cylinders
fireboat
Miami
My 2008 Yukon Denali with 105K miles suddenly started running really bad. The traction control/stabilitrac light came on at the same time.
I took it to a local shop who said I need to take it to the dealer. They felt possibly it was the fuel pump module (which has physical damage) and a new one would have to be programmed by the dealer.
I drove it a few miles to Williamson Cadillac here in Miami. The service advisor called me the next day and said that diagnostics points to no compression in cylinders 2 and 4. He said that he has seen this before several times with the 6.2 where it is a broken valve spring. However, it would be a week before they can check the engine out fully.
I have always cared for my Yukon with regular maintenance and do not drive it hard.
Obviously the engine is out of warranty but I was wondering how big of an issue is the broken valve and/or spring with the 6.2 non-AFM engine?
I saw one person with this issue on the internet but not much else, everything seems to be related to the AFM engines. I did find for the 6.2 a TSB advising to replace the engine if the intake valve is broken.
I am hoping it is just a simple spring replacement but I know if a valve dropped down and damaged a piston, I am looking at a new engine. I'll keep you guys posted as I find out more. Thanks
---------- Post added at 05:30 PM ---------- Previous post was at 05:02 PM ----------
My apologies, I just realized I posted in the wrong discussion area. Is it possible to move it? Thanks
NathanJax
Vacation Nathan
Jax, Fl
moved...
iNFamas
A broken valve spring isn't that big of an issue to replace. Any DIY'er that has the most common shop tools can replace a valve spring.
I dont consider a valve spring compressor and a spark plug air hose common in a DIY'er tool box and are needed for this job.
Broken valve means the head comes off for that fix.
F
fireboat
Miami
The dealer called back today and said it was two broken springs but there is no damage to the valves or cylinders. They will pay for parts (which isn't much I know but better than nothing). Labor will be $430.
I certainly could do the valve springs myself (I have built several motors and I have the tools and air) but I initially thought it was the fuel pump module and it would have to be programmed, which is why I took it to the dealer. Now, it's there, I am busy and I need it back soon so I'll just let the dealer do it.
BTW- Thanks NathanJax
iNFamas
Yikes 430 for labor!
slocaddy
sarasota fl
Haven't heard of fuel pump needing to be programmed when it is replaced, could you elaborate please?
dizhai
