2007 Tahoe Airbag Light Reset
2007 Chevy Tahoe
Airbag light came on, and dealer said it was front impact sensor code. Replaced both the front impact sensors, but airbag light is still on. Will the airbag light eventually go out on its own, or will I need to purchase a scanner to reset the code?
airbag light will go out if all is well, so something is still wrong or one of the new sensors is bad
91RS
GA
The airbag light in a GM vehicle will only be on if there is a current fault. Either the new sensors are bad or the wrong parts or they weren't the problem.
TollKeeper
Brighton, CO
Agree with the above.
Problem still exists somewhere in the system, or wrong parts
tired2008tahoe
ottawa canada
had the same issue with my 2008 if you are ordering aftermarket be careful cause mostly there are two part numbers. I'd suggest you buy an SRS scanner to save you the hassle of taking it to the dealership. An Ancel Fx2000 so cheap it costed me the same as an hour of inaccurate diagnostic at the dealership.
It could also be used to clear the codes so this way you dont have any memory DTC
I know for a fact that if you used a Dorman it will throw a code for “wrong part installed”. Not sure about the other aftermarket ones but it’s probably the same. You need to get it scanned again and tell us what the current code or codes are.
Durobans
