2005 Yukon cluster LED conversion question
Onebad1983
Resident Country Dumbass
Has anyone used superbrightleds.com to replace their cluster bulbs? If so on the quantity selection do I just leave it at one to get all the bulbs I need or is it talking about one bulb per qty?
Bombsquad85
Northern VA
For an 05 I used LED strips.
If you use individual LEDs you'll get hotspots. I placed the led strips around the bezel and I hsv uniform lighting all around.
The one with the CEL is the LED strip . You can see the difference
It's actually easier to use the led strips too. Instead of soldering each individual bulb you just need to solder the wires for the strips. I did the strips over 2 years ago and 0 issues so far (did them April 11, 2018 according to the time stamp on the photo)
Onebad1983
Onebad1983
View attachment 245680 View attachment 245682
I was worried to know if these were solder in or screw in like the 00-02 cluster. I can solder but I haven't practiced with hot wires (I know to disconnect the battery, but still)
NathanJax
Vacation Nathan
Jax, Fl
great website, 100% recommend.
Same as these guys say, 03-06 are LED's instead of 194 bulbs like the 00-02. Depending on the LED's you use, you could get hotspots...
Onebad1983
Onebad1983
Do you know if these LEDs would cause hotspots? And how long they would last? Also are their high/low beam bulbs worth the money? I'm using cheap eBay ones currently and I'm on my second set in 3 months
NathanJax
Vacation Nathan
Jax, Fl
I don't. I never swapped LED's in my 03, just in the 01
I took @Rocket Man advice and just installed these LED's in my Silverado. Obviously haven't driven at night yet, but maybe he has and can give feedback.
https://www.amazon.com/gp/product/B07NPMV1H5/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Bombsquad85
Northern VA
From my experience and in my opinion. The only way you won't get hotspots with those leds is if you had some type of diffuser over them or if its even possible to sand the led which would act as a slight diffuser.
I would consider the led strips if I was you its way easier and more consistent lighting.
Mezzo
LED swapping is easy just requires basic soldering skills,never tried LED strips,but dont cheap out on LED's and you will get hotspots otherwise ,Superbright is a great source for them and the shipping is relatively quick,also depending how close to the illumination lens the LED's are can affect the brightness,from my experience you want the LED's as close as possible with out touching the lens to help with an even brightness across the whole cluster
Karlus
Which model LED strips did you use and do you have pics of how you installed them? Are they dimmable?
CMNTMXR57
Chicago
If you get LED's with 360* coverage, you won't get hotspots.
I asked this question in the stickied thread, does the '03+ come from the factory as an LED? Seems as though that's the case based on responses in this thread. As such, no need to change them unless you want different colors.
I replaced the PC194's in my '99 with LED's, same warm white, just a crap ton brighter.
The Fahrens I bought on Amazon for my high beams work great. Great output and nice pure white. Also you can rotate them and set the vertical angle and hold them with an Allen screw so they’re aligned straight up and down where they’re designed to work properly.
Bombsquad85
Northern VA
I dont remember which strips I got. I think i got a roll off of either Amazon or eBay. And yes they are dimmable
jk6062
