2004 Yukon XL SLE TPMS Options
Piper724
Hi there folks,
I think the existing Sesnors are original equipment, so 21 years old !
All 4 tires are leaking at the Valve stems.
It looks like there are service kits available for that problem.
Rock Auto has these kits DORMAN 609104
We keep seeing the Service Tire monitor message over and over.
Since the Sensors have wee lithium batteries I am pretty sure they are over their Best Before Dates...
Question: Can these batteries be changed or are they sealed and a new Sensor is the only option ?
Rock Auto has new AC Delco Parts $83 each !
ACDELCO 15136883 GM Original Equipment; Programmed Info
LOW TIRE PRESSURE IND(UJ6)
I find it odd that you can't find these parts on the GMC Parts sites ???? Is this because the only thing left is NOS ?
Thanks
GMPartsDirect.com
15136883 - : Tire Pressure Monitoring System (TPMS) Sensor for Cadillac: Escalade, Escalade ESV, Escalade EXT | Chevrolet: Avalanche 1500, Avalanche 2500, Silverado 1500, Silverado 2500, Silverado 2500 HD, Silverado 3500, Suburban 1500, Suburban 2500, Tahoe | GMC: Sierra 1500, Sierra 2500, Sierra 2500 HD, Sierra 3500, Yukon, Yukon XL 1500, Yukon XL 2500 Image
Part Number:
15136883
GM
Other Names:
Tire Pressure Sensor
Replaces: 15102575, 15163069
Description: All models. Low tire pressure. This part requires programming and/or special setup procedures GM Service Information describes the... (...)
MSRP $111.70
$61.99
Add to Cart
P
Piper724
Awesome !
The picture helped explain the fact that you can't change the battery.
Ordered 4.
Thanks so much
Moderator
People's Republic of Colorado
The batteries are not easily replaced. When I got my Hoe at about 90k miles, three of the sensors had been changed to rubber stemmed ones, which I like better than the metal ones. Later on I had to replace that remaining sensor that had the aluminum stem.
Autel makes sensors with either metal or rubber stems, and they do have a tool -- and some of their scanners -- to do the initial programming that sets the frequency, etc. [MX 1-Sensor (M) or (R) suffix for metal or rubber]. Buying them singly runs about $30 each, with slight discounts for buying a 4-pack. There are places that will sell you programmed sensors so you're ready to install them.
I know you probably won't go out and buy a tool to program them but look here to see what they have. If you can install them perhaps a tire shop or another shop could program them for you. When they do that they can also set the sensors' positions (LF, RF, etc.).
NAPA listing for rubber stem: https://www.napaonline.com/en/p/ATD1SENSOR
Capybarbro
