2004 Yukon Daylight Running Lamps (DRL)
JochenWoern
JochenWoern
Sacramento, CA
Understood, thanks. At this point I am still waiting for suggestions in regards to my power issue.
I would swap the relay with a known good one that's the same style (believe the A/C relay is the same). With the relay out, though, is there voltage to the relay socket? I'm not quite sure which terminal to check as I don't have a wiring diagram.
JochenWoern
JochenWoern
Sacramento, CA
Tried that just now, unfortunately no change. Still no power.
There is only the 10Amp Fuse and the relay under the hood for the DRL's, correct? Or am I missing a fuse somewhere else?
Guess I will need to take the truck to have the Pros figure it out?
Do your automatic headlights work, by that I mean do they come on automatically when it's dark enough or the sensor on top of the dash is covered?
JochenWoern
JochenWoern
Sacramento, CA
Yes, they do come on.
On second thought, now I am thinking that they are on when it is bright outside, as I mentioned the other day that I thought the headlights were on when the wife came home from shopping in bright daylight. Which would mean the DRL's are obviously not coming on when the headlights are on.
Is maybe the sensor the culprit? I have a dashmat up there, may it is obstructing the sensor?
Am I correct in regards to the fuse and relay?
Thanks.
MassHoe04
Western MA
Thanks.
Dash sensor does need to be kept clear. That sounds like it might be a reasonable explanation for lights on in daytime and no DTRL...
Keep us posted.
Tahoer2008
