2004 Yukon..A/C just blowing, not blowing cold
mikemhp
2004 yukon slt 175,000 miles
recently replaced computer and fixed transmission issue-
A/C was working great, now just blows regular air. not hot nor cold no matter where the temp setting is
any suggestions?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
First: Look to see if the compressor clutch is engaged during operation. Second: If it is not engaged attach gauges to check pressures in system. You can also touch the shrader valve and see if you get any pressure out of system. Third: If it is engaged then you may have an actuator problem or control panel problem.
My guess is you have a low/empty system or maybe a pressure switch that is not allowing the compressor clutch to engage. You may also have a wire disconnected related to your recent computer replacement. By the way, which computer? How soon after the recent work did this a/c problem show?
mikemhp
mikemhp
update- hooked up a relay bypass tester to the a/c relay in fuse box, air conditioning came right on.
swapped out that relay (#8866) with the same one next to it, the horn to test. a/c still didn't come on, and the horn still worked
Drewphil
