2004 Suggestions
Justen Klemme
just bought an 04' with 115,000 miles. It has the all time AWD. I want to change the front and rear diff fluids and transfer case fluid. Do I go to the dealership and use what they recommend or is there better options? I already have spark plugs, front and rear brakes and shocks along with coolant flush in the near future. Any other things I should do for preventive maintenance? Suggestions for plugs and shocks that you have had good luck with? Thanks for the help ahead of time.
01ssreda4
I'd go with your basic fluids, nothing fancy. Front and rear diffs should like 75/90 gear oil, and the transfer case takes dex trans fluid.
