2003 Tahoe - parking brake question
DMSchuler
Clarence, NY
Had to replace the rear pads and rotors, and while I was in there I found the parking brakes were gone - no meat on them at all. Unfortunately, the screw for the bracket holding the shoe in place was so rusted it just snapped. The only way I can see to fix the glitch is to remove the axle. Before I go and do that, I was hoping someone here may have run into the same issue.
Any thoughts before I dig in?
Thanks!
KB01YUKON
did you replace the e brake shoe too? i have the exact same problem goin on also dust shield are about rotted off
Magnumac
on the 2000 suburban i had, I just took all the e-brake stuff out when it started to cause a problem, never used it anyway.
CKendrick
