2003 Tahoe dashboard paint peeling
texasag91
Has anyone had the problem of their dashboard paint peeling off? I have a tan interior but the paint has started to peel quite a bit.
Has anyone repainted and reinstalled?
What are my options?
Purchase new dashboard?
Thanks,
Jason A
el_flores
Common occurrence man. Mine's doing it too. Search around, tons of threads on this and how to fix opinions.
1sikrex
Armor all causes it to peel.
---------- Post added at 05:13 PM ---------- Previous post was at 05:12 PM ----------
Meguiars will not make it peel.
T
texasag91
I found few threads since i posted. Looks I am going to try the power wash and repaint.
JayXSP
Wallingford, CT
Just clean it with a degreaser, sand it with 600 grit to feather the edge out and paint with SEM color coat. I just did my dash today. Looks factory.
JayXSP
Wallingford, CT
This whole area was pealed and worn.
Spray light coats. It drys quick. DO NOT hammer the paint on. You'll lose the factory texture in the plastic.
T
texasag91
Wow that looks great. So they sell SEM paint in factory beige color?
JayXSP
Wallingford, CT
Yes. Go to a local auto paint supply shop. They'll most likely have it. If not they can order the correct color. Just so you know there are 3 different pewter colors for our dashes
JayXSP
Wallingford, CT
Thanks. The trick is to feather out the edges first with 600 grit paper. Some say you need to adhesion promote the plastic first... (i do custom paint/airbrushing for a living just for reference) and my experience if you just clean the surface well with a degreaser you won't have any adhesion issues. I believe the Color coat has a adhesion promoter already in the paint which helps.
el_flores
You do that all without having to remove your dash? I'm contemplating doing this but I'm debating on whether I should remove my dash to do it or just leave it in?
JayXSP
Wallingford, CT
I removed the bezel. And taped up the vents/radio areas. If you know how to spray you shouldn't have an issue. If u get overspray on the window it'll come off with a razor. I paint for a living so it was a pretty simple job.
Pachanga02
Ny
Wow that came out looking great Jay. I may have to look into this SEM paint for mine as it has a few wear spots.
el_flores
Jay, did you use SEM Graphite #15303 Color Coat to match the GM Charcoal dash?
Escalade2007
