2003 hoe
I finally bought my leveling kit. I got the 3 inch front and 2 inch rear spacers .
I was going to do it myself but a local shop said they would do it with an alinement for 350 bucks. So i went for it ..i got my truck back and everything looked good but the guy at the shop said he had to notch out the front upper control arm stop.. he said the upper control arm would hit it... did anyone else have to do any modification???? It doesn't change anything but it did bother me a little . take a look at the pictures and let me know what you think....I know i need bigger tires but these are fairly new.
Screwd up 6
I think that if any shop wants to be professional about something, they should call you before making changes that you did not discuss, even if it is free. Especially if it is something that is irreversible. I would have been livid if they did this to my truck…but then again, this is why I don’t trust anyone to work on mine.
Blazed
Accepting Donations
I'd be pissed considering you can't replace that.
Claymationzoo
Maryland
I wouldn't have paid for the work only the alignment cause that's some crap to torch your truck like that
576575
Los Angeles. S.F.V. & Lancaster CA
I've seen people doing the same when getting certain lift spindles (can't remember name) that said they'd work with stock control arms but would hit either way. I'm guessing that's why some kits come with new UC arms along with the knuckles..
06GMC5.3L
If that picture is at ride height there is no way the UCA would have ever hit the droop stop unless you went into a pothole deep enough to completely sag the suspension. From the picture it looks like the bottom of the UCA is a good inch from where the top of the droop stop used to be which is more than enough room. I am about 1/4-3/8" away and never hit it and don't have it notched so...
Sent from my iPhone using Tapatalk.
01TX_Tahoe
Semper Fi
Pasadena, TX
Wow! That's some hack job... I wouldn't have paid for that myself. They should've contacted you first to ask if you wanted to do it or not. Not very professional IMO...
Claymationzoo
Maryland
Didnt you sign a consent for only saying they can do certain work
Dimi3
