2003 GMC YUKON SLT Weird Goose honk noise from under Truck when accelerating from stopped.
eblopluto
I tried searching threads Didnt see anything. It just started. I tried seeing where it comes from while moving. I know when i am riding out the door i hear it under the truck. Any Ideas??
Sasquatch
Orange County N.Y.
Did you check for a goose under there? I can`t think of anything that would make a sound like that, Can you get the sound on video?
Scottydoggs
NJ
could be a dry slipper yolk on the front driveshaft. its called brake squawk. gm has one of them hidden TSA's on it.
if when you come to a stop the nose of the truck stays down, then you let the brakes go the front end comes back up with the goose sound. then its a dry slipper spline for sure.
zdude
Atlanta, GA
Is yours a 4WD? Does it do this regardless of whether the AC system is on or off? Do you have any clunky feedback in the vehicle when it makes this noise, or only an audible noise?
Mine is 2WD, and I had a weird noise a couple years back that was related to AC compressor. I noticed the noise and a clunky jolt when accelerating, mostly from a stop, but would also occur less frequently when accel after already moving, like when passing a car on the hwy. After I while, it snapped the AC belt. I replaced it, and it did it again after only a week or two.
After changing the belt and the tensioner, thinking the tensioner was going bad, I read about the original AC compressor design being such that over time, an excess of refrigerant oil will accumulate at the compressor input and the reed valve design would allow it to enter, and guess what happens when you try to compress a liquid?
I replaced the compressor and some other components, and haven't had the issue since.
Just something to check...
sticky brake caliper? I would have a brake inspection done that can tell you a lot and shouldn't cost anything from many places
Mine makes a similar sound in the same scenario. I'm thinking it's worn link bushings or one of the blown rear shocks. They're trashed.
WITCH1975
