david76008
- Joined
- May 15, 2014
- Posts
- 34
- Reaction score
- 0
Nice lil process. You've done more in a month than most people will do annually!
nice truck.....very motivating
Nice job! I'm digging that blue. It looks great!
The truck looks level. What did you do?
Loving this thread. Thanks!
Is it 4x4?
Hey tgui, what's the trick in getting that dang flex fuel filter off? I bought that red OTC tool you showed and I can get it under the quick connect fitting but I can't get the fitting pulled down over the tool to release the clips.
Any advice?
Shoot. All I remember is that I had to bend and twist that tool into place, one side then the other. I had to pull back on the filter to make room I think as well. Then it was a matter of cussing and pushing the adapter forward with a long screw driver as a lever. In a fit of anger I tried yanking things apart again and the filter came off!
I've heard that shops sometimes skip what I did and just cut the filter out with large snips. I certainly would give this a shot, just dont grind it off... since gasoline and sparks are baaaad.... mmmmmmkay!
Good luck its a *****!
