2002 turn signal mirror conversion
monkeywrench71986
Hi I'm carpentar,
Saw a post about turn signal mirror conversion from 2002 using 2004 mirrors (note) if your Yukon DOES NOT have defog this is all you, Yellow up down left and right light blue in out passenger. Light green drivers. Mirror indicator brown black stripe ground GREY W BLACK STRIPE light blue FROM BCM connect both and **** test route wiring and seal connections w desired connectors
for the 00-02 it's easy, all you need is the glass with led signal, then run the 2 wires, 1 wire is grounded (on the door frame), the other wire gets fed thru the door to the bcm turn signal positive output. the output wires from the bcm for turn signal are blue/white.
Dh1280
