2000 Yukon. No battery. No Key. Stuck in Park. Need to move
Bruinshockey78
My truck has been sitting for a few years and I've since lost the key. There is no battery in the truck. It's a lawn ornament at this point but I need the room and need it gone. The kids took the key and lost it. I only had the one. Is there an easy way to shift into Neutral so I can have it junked? I'd like it gone ASAP. I did a search here and the only thing relevant was a linkage in the transmission? There's snow in my yard and it will be there for a while, so getting under it won't be an easy task, at least not for a bit. I hope there's another way. Help?
B
Bruinshockey78
Any towing company can yank that right out of there with a flatbed.
If it's as simple as that and won't be a problem for them, then great. I'm not worried about ruining anything on the truck since I'm going to junk or donate it anyway. I just didn't think that was a thing that they would do. Great news, then. Saves me a bunch of time. Thanks!
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
A flatbed can back up to it and drag it. If he gets the back of the bed down right in front of the front tires or rear tires they will not drag in the yard but the other end will unless they drag from rear and the front tires still roll. If enough snow that flatbed may have to be far enough away that the tires drag in the yard but the snow should help with the slide. Or you get under it and remove driveshafts and it will roll no matter what.
Sure picked the wrong time of year to get it out of the yard.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Tow truck guys love to show, off shouldn't be an issue there.
rgosart
Can you disconnect the shift cable underneath and shift it to neutral?
drakon543
im not 100% on part of this but most vehicles are shift locked inside the vehicle im not sure on yours. alot of vehicles have a method of unlocking this feature mechanically for this exact purpose. you can also chock the wheels slide up underneath and pull the shifter arm off the transmission and turn it with channel locks or vice grips. ill also see if i can find a specific method of disabling the shift lock. but also yes most tow truck drivers like to show off. bunch of awesome videos of really neat recoveries by tow truck drivers. course there also a couple of pretty awesome fails too.
OR VietVet
Willamette Valley
When I lived in KC, Mo. I used to run a tow truck o weekends as an on call driver. The first 6 months were great and saw a lot of strange things but I quit one day after a call was over. A car with a family of 4 in it ran a stop sign near a small gas station and grocery store in the country. There was a flat bed truck coming right at them. The truck was there, completely off his route because he was running around scales. That truck plowed over the car and trapped it under the tractor and slid into the gas station before it stopped. I had to hook up and pull/roll the tractor off of the car as another tow truck dragged it out from under. All four, 2 kids, were killed on impact. It was a mess to say the least. I handed in my keys right after that. Tow truck drivers that can last thru something like that are made of something I am not. After all, someone has to do it.
89Suburban
SE PA
You and Hotrod would get along. He's our kind of people.
OR VietVet
Willamette Valley
If he is mechanically inclined, turned wrenches either as a tech or on the side, likes guns, drinks beer or bourbon, likes to help people/friends, former military or military family........yea, we would likely get along. But if one of the Babes of the Day walks in and I have half a chance, all bets are off........:cool:
BG1988
go to the dealer and get a key it's like 12$ for that old tahoe or you will a title or registration and a ID (cut from VIN not a copy)
JeffL
I say paint it bright fun colors and make a fort out of it
Drewphil
