2/4 with 22’s
95escahoe
I’ve got a 2004 Escalade that I would like to lower 2/4. I currently have 2016 Escalade rims with 285/45/22 tires would I have any rubbing issues with these rims/tires? I’m going to use 2” lowering spindles up front and 4” lowering springs in the rear besides that would I need to do anything else suspension wise?
Thanks
Bombsquad85
Northern VA
Thanks
I can let you know next week lol my wheels are 22 with the same tire size and I have the same drop. Not sure of the offset or backspacing difference between our wheels because I don't know mine haha
95escahoe
95escahoe
Sounds good besides cutting the balljoint bolt in the front did you need to do anything else? I’m pretty sure you did drop spindles too
Bombsquad85
Northern VA
Just theupper ball joints bolt. I need new UCAs tho I found that using a big C-Clamp to pull the UCA down helped slot. I wish I did that initially. I screwd my BJs up by using vicegrips
MrBalll
West Texas
I have 22s and only have a slight rub on the plastic behind my driver front tire. Not an issue at all, just keeps the plastic wheel well cover clean in the small 2 x 2 spot.
No catching or rubbing that would destroy or mess anything up.
Riki7s
Put Pirelli 285-45-22’s and a Belltech 2/5 lowing kit. Same minor issue as Mr Balll slight rub barley scrapes on dips at higher speeds than posted at left front wheel opening plastic trim.
D9F8A6A7-96AA-4E35-AF44-7EDC8755E018.jpeg 99E11352-8798-4623-9097-76EF25ECFCED.jpeg
Da90
Tulsa, OK
I am running 305/40/22 on a 3/4 drop. Rubbing is very minimal.
NORCAL SS
SUV SUSPENSION GURU
Oh in rear will need to trim plastic fenderliner. Thats nithing major
NeverSatisfied
eBay Baller
Wichita, Kansas
I went 5/7 on 285/45/22s and the rubbing wasn't as bad as you would think lol
but since you are running a factory wheel and offset you should have very little to no rubbing up front. Like tony said you will need to trim some of the plastic liner at the back. I suggest the adjustable panhard bar, will make the trimming even less. Also flip the top shock bolts on the rear shocks while your in there.
Here's The Beast on 22's with a 2/4. I ran 26's with some rubbing even with some of the inner liners cut out. The 22's don't rub at all. Flip the rear shock bolts like was mentioned, also might need the DJM rear endlinks or free travel mod but you will know that after you drop it and drive over some hard bumps. If anything bangs back there you'll need them. Don't forget you def need rear shock relocators or your shocks will bottom out. My side-to-side difference was only 1/4" -3/8" so the adjustable panhard would have only netted me 1/8-3/16" in extra clearance on one side which I didn't need. After the drop, check to see if you moved enough to rub on the side of one tire in the rear and if so then you'll need the bar to move it over. For a 5-6" drop you would def need it.
Bombsquad85
Northern VA
I have the 2/3-4 drop set at 2/3 and I have no rubbing on my 22s with 285/45s
If I can get this free travel model done I will take the spacer out and do 2/4 and maybe get some keys to do 3/4
Bombsquad85
Northern VA
View attachment 202180 Here's The Beast on 22's with a 2/4. I ran 26's with some rubbing even with some of the inner liners cut out. The 22's don't rub at all. Flip the rear shock bolts like was mentioned, also might need the DJM rear endlinks or free travel mod but you will know that after you drop it and drive over some hard bumps. If anything bangs back there you'll need them. Don't forget you def need rear shock relocators or your shocks will bottom out. My side-to-side difference was only 1/4" -3/8" so the adjustable panhard would have only netted me 1/8-3/16" in extra clearance on one side which I didn't need. After the drop, check to see if you moved enough to rub on the side of one tire in the rear and if so then you'll need the bar to move it over. For a 5-6" drop you would def need it.
I can't get over how gorgeous your truck is!
What hood is that? And where could one pick something like that up?
95escahoe
95escahoe
Thank you sir. It's a Goodmark cowl hood. I had my body shop pick it up but you can find them on Ebay or online. Here's an EBay link for a Tahoe one:
https://www.ebay.com/itm/Goodmark-C...853509&hash=item440ce0eab2:g:lQUAAOSwY~laAzhM
Goodmark makes a great hood I had one on my OBS Tahoe, I’d highly recommend getting it through a local shop tho, I ordered mine offline it came damaged and was a hassle to send back got the money back and had a local body shop get it for me was actually cheaper there
Bombsquad85
Northern VA
vtxtexan
