1999 Gmc Yukon Electric help
B
BradyBargo
the interior lights that’s activated by door when open
Do they get power from the 30 amp breaker I’m listing above cause they don’t work without it in I’m just trying to figure out where these problems are and what to chase on the fuse panel diagram I don’t see where it states it controls the door lock control module
B
BradyBargo
With seemingly unrelated circuits causing problems, I would suggest you check the main interior wiring harness. You probably have one or more wires making contact with the body(ground). Electrical problems suck.
Are you referring to the one behind glovebox or under steering Column
NoReverseYukon
NE Wisconsin
I have a NBS (2001) so I am just about at the end of the suggestions I can offer on your OBS. But I would think that you have some wires running along the side under the door jamb trim piece or under the carpet. Those wires are what sends power to the seats ( 1 of original problems ). Good luck, but I'm gonna tap out now.
exp500
Post the manual diagram page you are working from, then we can walk you thru the most likely steps for a proper diagnosis/ repair. May be 3 or more pages each showing the components you have mentioned. A failed relay can move in many directions because some fused some unfused as you have noticed.
B
BradyBargo
Hello guys haven’t touched this thing since I made this thread another thing going on when I speak of interior lights none of the 4 lights on the doors even come on wonder if I have a issue there? Causing other issues
GMCChevy
It's probably all related. You still need to to check that circuit and see what alls on it as a start to figuring it out.
conner04
