1997 Yukon PRNDL indicator light issue
Jmoore
i have a 1997 Yukon. When I put it in Park and turn off the engine the Park indicator light on the dash stays lit up. My battery drains down and I feel like this is the reason why. Does anybody know why the light is staying on? When I rotate the key all the way back to accessory mode it goes off but of course I can’t take the key out. My battery draining is driving me nuts!
east302
Mississippi
It looks like the transmission range switch grounds certain circuits to show the indicator light on the dash.
It gets power through the instrument cluster from fuse 20 (circuit 1020) and fuse 9 (circuits 1382 and 8). So, to me, this means that you’re getting power to the instrument cluster when you’re not supposed to.
The diagrams below show the routing. Circuit 1020 is straight from the fuse, the other two go through the headlight switch.
You could remove the cluster (ignition off) and use a mulitimeter to see if you have voltage on any of the three pins from 8, 1020 or 1382.
Here’s the pinout for the cluster. I would test 7, 8 and 29 each to a ground and see if you get a voltage reading. With ignition off, there should be no voltage. The cavity/pin showing voltage would be the culprit. Or, at least, that’s what makes sense to me.
Another idea: rotate the headlight switch dimmer dial up and down with the ignition off. The PRNDL indicator shouldn’t respond unless there’s voltage.
Good luck, I hope this helps.
J
Jmoore
Thank you so much for the information! I picked up an instrument cluster today at the salvage yard. After I pulled a couple fuses and the voltage dropped off I'm hoping changing out the cluster will remedy the problem. If not, I'm out $50 and a little bit of time so will see from there.
liquify33
Houston
if it’s NOT the cluster, test the salvage one for motors/gauges as they are pricey to replace. The lights are cheap but the fuel gauge motor and a couple others are $50-ish new. That secondary circuit board behind the gear indicator is nearly priceless as well.
J
Jmoore
I think we figured out it is the gear switch attached to the transmission. I have my fingers crossed!
drewlester77
