1996 GMC Yukon 2 DR, 4WD, Lower Control arms
Smalltalker
I am looking for the lower control arms for a 1996 GMC Yukon (2 DR, 4WD) with ball joint assembly.
Can't seem to find them anywhere. Is my only option to try and rebuild the current ones with bushings and ball joints?
All the other parts in the suspension were replaced.
No luck at NAPA, RockAuto, Ebay, etc. Only lower control arms available are for 2WD models (go figure since you would think most of the models sold were 4WD)
Any help/guidance is greatly appreciated.
strutaeng
Dallas, Texas
Those have been discontinued for some time now. If they are serviceable, just replace the bushings and ball joints. Otherwise, junkyard or part-out-special would be the only option.
I've done bushings and ball joints on forged LCA with C-clamp style press and a shop press. It's not too bad once you figure stuff out. A bit of heat helps removing the old ones out.
S
Smalltalker
Thank you.
strutaeng
Dallas, Texas
How can I tell whether I have the forged LCA or Steel Stamped LCA?
The stamped LCA are like formed sheet metal and welded (hollow). The forged are a single, solid piece.
I'm trying to remember, but I think in your generation, only the 8 lug LCAs were the forged ones? I don't own a K1500 series vehicle, so I can't confirm.
Someone please chime in.
S
Smalltalker
Thank you all for the help. Mine turned out to be the steel stamped LCA. Replaced bushings and ball joints.
Durobans
