1992 Blazer won't stay running
jonhowe88
Houston
I have a 1992 Blazer. I really need some help. It has been starting just fine when cold, but once warmed up it doesn't stay running unless I work the throttle. After working the throttle for about 30 seconds to a minute it runs and idles fine. It has now started randomly dying at stops. I start it back up and runs fine after. I did a fuel pressure test on cold and hot engine and the fuel is getting to the throttle body. Not sure what to do next, does anyone have any other suggestions.
Eman85
Check engine light? Any stored codes? Throttle body clean? Need a scan tool that can read and control the IAC motor and see if it's working correctly. They are bad to have throttle body gaskets break/leak.
curbud
