08 Tahoe idle surge at low idle. HELP
Book_em
I have a 2008 tahoe 2wd PPV with 240k miles. Not always but at least 6 times a day while in gear at a stop light the idle will drop from 600 to 300 and kick right back up to 600 and act like it never happened. Feels like it wants to stall but doesnt. The only thing the dealership can tell me is my fuel trim reads from 23 to 40 percent but cant tell me why. Keep in mind no codes. Since this started to happen about 4 months ago i have installed the following parts all from GM with no avail. Please help.
New throttle body with tps
New alternator
New belts and pulleys
New starter
New maf and map sensors
New ac compressor
New plugs and wires
New up and down 02 sensors both sides
New transmission
New airbox
Any help or ideas would be greatly appreciated
kbuskill
NE. FL.
Does this happen with your A/C on or off or both???
Kraig
I’m going to take a stab in the dark and say you should try the Big 3 (or 4) upgrade and see if it helps. If it doesn’t, it was a good idea anyways.
BG1988
New alternator
New starter
New ac compressor
New plugs and wires
New transmission
New airbox
fixing random parts eh?
more then likely a vacuum issue... check the vacuum hoses
or faulty
IAC valve (idle air control valve)
992dr
Eastern N.C.
Welcome aboard John
Mine has done this in the past and does it every so often. Can be pretty annoying. No codes here as well.
I have about 220k miles.
In my most recent research and from what I've read in the last, I had read about fuel injectors causing this same issue. Also something about fuel injectors dripping down. I will be replacing mine this summer.
B
Book_em
I will be doing this in the coming weekend. Thanks for the idea
B
Book_em
or faulty
At least once i fix these parts i know they are new and when replaced. Im really trying to keep this truck long term.
All vacuum hoses have been replaced and as far as i know this truck doesnt have an IAC valve as its part of the throttle position sensor. Which is new also.
B
Book_em
Welcome aboard John
Thank you.
I will also look into this as a possibility and keep you posted. Thanks again.
My67goat
