@TanklessPro, if there is a way to check or set the date, look for that. Not sure if it would be automatic but, if not, it could have reverted to the wrong date (and year), like some time during DST.
No date option. I went through the compass and nav settings and everything was fine.@TanklessPro, if there is a way to check or set the date, look for that. Not sure if it would be automatic but, if not, it could have reverted to the wrong date (and year), like some time during DST.
maybe it just needs a firmware updateNo date option. I went through the compass and nav settings and everything was fine.
BfhHow do you do a firmware update?
I have this same issue... GPS Coverage area screen on the nav says that the truck is in CST land, but we are really out here in California, which makes the time 2 hours off. Tried disconnecting GPS antenna, re-start, stop, re-connect as suggested elsewhere but no luck. Tried the hidden Nav screen to manually set the time to proper, but within a few minutes it reverts to 2 hours off. Open to other suggestions. For real. Thanks...@TanklessPro, if there is a way to check or set the date, look for that. Not sure if it would be automatic but, if not, it could have reverted to the wrong date (and year), like some time during DST.
