07 Yukon Denali - Master switch won't work, only window switch on passenger side works
mwaoh
2007 Yukon Denali XL, the master window switch doesn't work at all (locks, mirrors, heated seats, windows), and the two window switches in the rear do not work. The passenger side window switch does work.
Tried replacing the driver window switch and replaced some fuses, but no luck.
Did you replace the entire assembly? With new or used?
A new piece must be programmed to your vehicle. A used part may work if your car has the same options as the donor. The rear switches do not need programming. They are about $10 on ebay from the same company in Mexico that makes them for GM. Switch Doctor if memory serves.
wjburken
Eastern Iowa
If I am not mistaken, you will need to have the door switch programmed to match your vehicle's options. If you were able to find a used one at a junk yard from a vehicle with the same options as your vehicle, you would not need any programming.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Troof to deese! Just went through this myself. I found a used one on eBay and it worked.
91RS
GA
Proper diagnosis would have been to at least check for power and ground before throwing parts at it. You probably have a broken wire or wires in the pass through wiring.
M
mwaoh
Does it need to be the same year as well, or would one work off a 08/09 if it has the same options
CaptainAmerica1
Arlington TX
Don’t wanna be that guy but have you pulled the switch apart and cleaned up the contacts? Not rocket surgery and definitely worth the effort
veteran111
