07 Tahoe PPV Speedometer & Tachometer Reading @60MPH
jz57
Like the subject says, what is your 07-Up Tahoe PPV Speedometer & Tachometer Reading @60MPH?
My 07 Tahoe PPV has 2000RPM reading while @ 60MPH. The tire size is 265/60-17 (Police package size), 4L60E 4-speed transmission, axle ratio: 3.73
Looks like the engine RPM is higher than my 12 Dodge Caravan, which has 1500RPM @60MPH even with a V6, 3.6L engine.
What is your idea and explanation?
TheFuzz
Idiot Police
Spurbury, VT
Assuming no mechanical issues, higher RPM = lower final drive ratio. Is it possible that someone re-geared your truck to 4.10 or something? Either that or your trans isn't shifting into OD properly.
tights24
Yeah, I think that's pretty far off. I don't think I have 3.73's in my truck,3.44 or something close to that, and it's not a PPV, but it's the same trans and 4 speed. I think I'm doing close to 80 if not over that at 2000rpm's. The poster above nailed the two things I would think of also. Either re-geared, and above 4.10's for that high of an RPM at 60 IMO, or you're not getting into OD.
Will the Tow/haul button on these things prevent you from going into OD or does it just keep the TC from locking up too early? Sorry, I'm new to these trucks as well, but in general something isn't right.
TheFuzz
Idiot Police
Spurbury, VT
To echo what Tights said above (and just for reference), I drove to Ft. Collins and back along I-25 last week, and with the cruise set at 75-80, I was just a hair under 2500 RPM, IIRC. 3.73's in mine.
Tow/Haul activates a different set of parameters for the TCM, it changes the shift points to settings more optomized for towing. As far as I know, it doesn't prevent the trans from going into OD or affect the TC lockup at all. Doubt it would have that much of an effect on RPM but it's worth looking into.
ezdaar
Chat Troll
Redneck central, Aka Houston
/offtrack a sec
muuhahaha! the Tow haul button can do some Really fun stuff to your trans!
Just need a tuner who knows how to mod the tables properly and it opens a whole new world.
/backontrack...
BEEMDUB
PIMP DADDY FLEX
Michigan
my truck is at 2k rpm when I'm at 66mph, I know because thats what I set my cruise control to everytime I'm on the expressway
Blazed
Accepting Donations
According to gear ratio calculators you have 4.10s
1,960ish or so is what you should be running
1,600ish with 3.73s
I think someone regeared you.
tights24
Ya know, with Beemdub's comment about his PPV and speed, is it possible that 4.10's are from the factory for those trucks? I know GM offers a ludicrous amount of different gears for the trucks. But if he's doing 66 at 2K, and if your calculations are correct for 1960rpm @ 60mph, maybe that's what's going on. Just a thought. In a way it would make sense since a typical PPV will want to launch hard as hell to catch up to someone and 4.10's would definitely do that..... Top end would suck, but what do they care if they wind it out.
Blazed
Accepting Donations
I could of sworn ppv have 3.73 factory so they can jump but still go pursuit speeds
TheFuzz
Idiot Police
Spurbury, VT
It depends on how the department that owned the truck wanted it set up. I know for a fact that 4.10's are offered as a no-cost option for the fleet order forms; police vehicles are built to order so it makes no difference to GM what gears they put in. I was operating off of the assumption that the OP knew for a fact that the truck had 3.73's in it, but if he didn't confirm that via the VIN then it's entirely possible that it came with 4.10's.
Blazed
Accepting Donations
Or RPO code in the glove box.
Gtu4 or gt4 I think
J
jz57
OK, confirmed here:
Pro code label in glove box:
GT4 / REAR AXLE, 3.73 RATIO
Z56 Police Package
Police Package Tire size: P265/60R17
(Civilian version tire size: P265/70R17)
I double checked Speedometer & tachometer readings while driving in hi-way: 65 miles/hr and 2000 RPM. My previous posting was off 5 miles/hr. Sorry for the mistaking.
The engine RPM @ 65MPH is still higher than regualr civilian version Tahoe.
Could that be police package tire size ?
Gtu4 or gt4 I think
Blazed
Accepting Donations
Yep that's it.
flyerstump
http://www.gmfleet.com/police/chevy-tahoe-2wd-ppv.html
Here is a start to getting info, on new ones at least. I have a '14 on order, due in October (can't wait), I believe only gearing offered has been the 3.73's. I couldn't order any different, other than adding the Posi unit. i wanted to go numerically lower if I could have for better mileage. (personal car)
worleytrev93
