Thank you for the quick clarification. Much appreciated.
It looks like they were not working before you changed them, correct?
Did you replace them with incandescent bulbs of the same generic part number?
Did you check fuses in the fuse boxes? I don't know if they use a separate fuse, but some folks here on the Forum will know and chime in.
I know that the socket is small, but have you tried to get the probes of a volt meter into the socket and onto two contacts to see if you are getting voltage to the sockets? You may have a broken wire leading up to the sockets.
