04 Tahoe Rear Shock..Upper Bolt
Flamingdecals
Tejas
Just lowered my Tahoe... need to change out the rear shocks... should be easy, only two bolts. I can't access the top one though. Any tricks to getting the top bolt out.
thehoe92
fo sho
The916
extensions are your friend!
I remembered taking it off wasn't as hard as threading it back on
have socket with the extensions on it rested up against something and use the other wrench/socket to loosen the nuts so you aren't fighting with trying to keep your socket over the bolt on the extension if that makes any sense
CKendrick
