clemet
Ok so here's what I have done so far, and this thing is really starting to annoy me. I had changed out the rear pads, and then started getting an ABS light and codes C0238 - ABS wheel speed mismatch, C0223 - Rt front wheel speed signal erratic, C0237 - Rear wheel speed erratic, C0236 - Signal missing. I tracked those down to the right front sensor having a broke wire in the harness which I swapped out with one I had laying around after changing out the left hub. Right now I get 1k ohm resistance across both sensors at the EBCM, and codes c0221 & c0229. After I replaced the sensor I checked the voltage while spinning the hub and got 1-2 vac at the sensor. Ok so with the codes I figure that the tone ring is not quite right or something else in the hub is causing the issue. I will be replacing it shortly. I drove it yesterday after the sensor job and all was well other than the codes.
