Fabtech Lift Kit
99 2dr
The Real Nor Cal !
Hello, I am looking at purchasing a 98 2 door hoe for the GF...... The only thing i don't like is that it has a 6" Fabtech lift. She is 5'3"..... How low can i make the truck lower without taking the lift off? I wouldn't mind 3 inches..... 6 is just too much. I would just take the lift off however i don't have the factory parts. Can I just lower the back with shorter blocks and un-crank the front? I have never had any of my hoes lifted, i just always leveled them with the bars.
Thank you
Kyle
96ProCompTahoe
IN
you should be able to swap the blocks and decrank the front to about a 4" lift with the CV axles laying flat. if thats not enough you can throw on some steps.
Nikolai553
Hutchinson, KS
I think you can install some lower step sides or nerf bars instead if you dont wish to lower the entire truck.
99 2dr
99 2dr
The Real Nor Cal !
Thanks guys, Right now the truck has 20" wheels and 35's on it. I don't care for that look. I have some 16's already and i was considering changing to 33's would that still look good in your opinion? It would also lower the truck even more.
MeanSlickCaddi
