2012 Tahoe won't start first try, loses fuel pressure overnight
TeIam25
2012 Tahoe LTZ Flex Fuel 162,000 miles. I've been chasing a long crank and couple attempts at starting each morning and afternoon leaving work past 2 weeks. Once it starts, it's fine but once I shut it off for a couple hrs, its hard to start. No codes have shown up. In the morning it's just long crank then stops, try again, long crank, stops. Try again and it fires right up. Sometimes on the second attempt it fires up. In the afternoon it would immediately start and then sputter and die. Try again and fires right up. Thought maybe Camshaft sensor but that didn't fix the issue (that was fun to replace ). Cleaned my MAF and throttle body, but didn't help. New battery, no help. Fuel pump replaced 4 months ago with Delphi DFG1054 fp, I know it's not the flex fuel pump but i don't run flex fuel anyways. Got my hands on scanner and when I checked my pressure after I got home from work yesterday, it was at 43.5 while running. Shut the vehicle off and fuel pressure rose to approx 70psi and I unplugged the scanner and went inside. Came out this morning and had 0psi. Primed it a couple times (with scanner running) and got it to 42psi and it started but sluggish as expected. But pressure went up past 58pso then leveled out at 43.5psi. Ran to the store came back and shut it off vehicle but kept scanner on, and for an hour I watched it, went upto 78.3psi (within about 20 mins of shutting vehicle off) and then finally started to lose pressure very slowly. Went inside for another hr came out and was at 40psi. Stared up but sluggish. I really don't want to swap up again. Possible injector issue? I put Lucas Oil Injector cleaner in and it started up fine next morning first try but after that it's been the same struggle. Any help is greatly appreciated.
Fless
Moderator
People's Republic of Colorado
Do you mean that you know that the fuel pump is not causing the issue (because it's new?), or that you didn't install the Flex Fuel pump?
FWIW Rock Auto shows that to be the Flex Fuel pump. See graphic below.
Did this start right after replacing the fuel pump? I would suspect leaky injector(s) or the pressure check valve in the fuel pump is not holding the pressure. However, a leaky injector is going to show up as flooding, but with your fuel pressure test on the scanner, it appears that the leakdown is likely elsewhere.
It might be advisable to manually test the fuel pressure on the rail to confirm that the scanner is reading correctly. There is also the possibility of a defective fuel pump control module.
If none of that is conclusive, then pick your poison. There's probably some way to plug the fuel line before the rails to see if the pump is bad. I'm sure that other members here will have suggestions.
T
TeIam25
I don't know if it's the fp or not, praying that it's not since it's a pain to drop. I was stating per the number I have for the fp that its not for flex fuel. Once I replaced fo back in April, it ran and started up fine, this issue has been happening last 2-3 weeks. I'm going to get a manual fuel pressure gauge and test that way even though I feel confident the scanner is accurate. But was also confident putting a brand new Delphi fp in wouldn't have any issues this soon but here we are with it possibly being the culprit lol
Fless
Moderator
I'm not sure where you're getting your info but that pump is the one for the 5.3L engine, per Delphi. You didn't specify which engine so this doesn't apply if you have the 6.0L (would take FG1153, non-FF).
40 after siting for an hour or 2 is perfectly normal, the overnight 0 is not
the higher pressures after driving or running the engine and sitting is "heat soak" and also normal
if the problem was not present before replacing the pump, then it's the likely culprit.
if it stinks like gas fumes, smokes, etc after sitting then that points more to leaking injectors
since it is under warranty I would try the fuel pump first. just drive it till it's pretty much empty.
if you monitor the fuel range in the dic you can get it down to the last 5 gallons or so pretty easily, once it shows just "low" (on a flat surface) then park it and lit it idle either for hours or until it runs out.
on a side note these vehicles can idle on fumes for a very long time, for instance 5 gallons of gas could take 10 hours to idle out
a faster way would be to attach a hose to a schrader valve fitting on the fuel rail and key-cycle the fuel out
43.5 psi is normal operating pressure once the engine is warmed up. Do you have any fuel soaked spark plugs? If not, I reckon your new pump is no good.
Don't go thinkin' you know more than the engineers and put parts in there that it wasn't designed for. GM OE for the win. In your case that's a MU2139/19299718 or MU1876/19541373. The latter was superseded by the former.
@Fless 2010-2014 Tahoes have 5.3s only from the factory and they were all FlexFuel engines, LC9 or LMG.
Fless
Moderator
I stand corrected. The hybrid has the 6.0.
And you have it backwards; the one ending in 1373 is the current part number, according to the online GM stores.
houstontaylor
My car was recently taking more cranking than is normal to start up even though the fuel pump's relatively new. I have been using probably the not best gasoline from the local grocery store . I figured it was the fuel pump check valve operation getting impeded and tried putting Chevron Techron fuel system cleaner in the tank and it fairly rapidly started working as it should again.
T
TeIam25
Thanks for the insight on the fuel pressure after shutting it off (heat-soak). This issue didn't exist before replacing the fuel pump, I cheaped out and bought an aftermarket fuel pump from Rock Auto and it was sending the needle all over the place and hardly ever got an accurate gauge reading after little over a yr of it being installed. I ran out of gas when the gauge read differently and said I'm done and replaced with the Delphi fuel pump. Now unfortunately I needed to put gas in yesterday and I decided to put Injector Cleaner in as well (this is the 2nd time I've added Injector Cleaner since this issue started), didn't touch the vehicle after arriving home, sat all night, got in it this morning, turned key to "on" position to get fuel pump to prime once and immediately started. Both times I put the Cleaner in, it started right up next morning. But in the afternoon leaving work, it sputtered and died on first start up. Tried starting again and fired up. Feels like a stuck open Injector?? I'm pulling plugs this week to check for any wetness or fouling.
T
TeIam25
Yeah I knew the 43.5 psi was good, was just stating that it was sitting fine once started and such, just would lose all pressure by the next morning. Couldn't wait on ordering from GM and had read GM, A/C Delco and Delphi were the acceptable part brands for a Chevy. Granted I don't know more than the engineers but would love to know the reasoning behind putting everything inside the tank. More hassle to deal with than before. I'll pulling plugs this week to check for wetness or fouling. Did put injector cleaner in last night with 15 gallons of gas, fired right up this morning, this afternoon it fired, sputtered and died, then fired up on 2nd attempt. This is the second bottle of cleaner I've put in since this has started, both times, same result so far. So maybe injector problem??
Fless
Moderator
I doubt that the timing of the injector cleaner has anything to do with the start-stall in the afternoon. I'd be monitoring the fuel pressure before and after starting it. You can do that with a scanner watching the commanded (desired) fuel pressure and comparing that to actual fuel pressure, or by putting a manual fuel pressure gauge on it to see if it's dropping out.
If the behavior is consistent and you can easily replicate it, try using clear flood mode next time it is expected to happen. Floor the gas pedal, then crank it to see if it starts; if it does, let off the gas and see if it continues to run. Watch the rear view mirror to see if black smoke is coming from the tailpipe; that would be a clue that it's over-fueling.
If clear flood mode lets it start and run, then you may have a leaky injector or something as simple as a mis-behaving evap purge valve on the engine.
Putting the pump in the tank allows it to be cooled by the fuel and they've been doing it this way since at least the 1980s. Before that we had those mechanical pumps attached to the front of the engine cover but those only made about 5-6 psi. I replaced more of those than these in-tank pumps since.
Let us know how the plugs look. My money is on the pump, there's a part inside it, like a one-way gasket or valve that is bleeding off the pressure too fast and working against the pump building pressure. I forget what it's called. Every so often someone comes on these forums with those exact symptoms and it's usually from a new aftermarket pump or a very old stock pump.
If it were a stuck open injector, I reckon the duty cycle of the pump would shoot up trying to maintain 43.5 psi and you might have white smoke or raw fuel coming out of the exhaust depending on how hot the cats are.
alexblagoev
